Been there, done that *LINK*
Grant in Iowa
>Before you leap, look around at the alternatives. May I suggest the tool linked below, which I have and HIGHLY recommend. I also have a DeWalt drill and impact driver, but I give the edge to the Makita.
If you have both an impact driver AND a drill, there are a number of advantages:
-Two tools, so you can predrill with one and drive with the other
-Impact drivers cause less fatigue when driving large fasteners. THe impacting action means no "opposite reaction" on your arm and elbow. Ever get a sore elbow from using a drill/ driver all day? Not with the impact driver! The 14.4 impact driver will drive deck screws all day long, and faster than an 18V drill/ driver.
-smaller, lighter tools are easier to handle.
-Impact driver causes less bit slippage than a cordless drill. When driving a screw, the bit reseats itself into the screw on each blow. Contrast that to a drill driver which provides constant torque, causing the bit to want to cam out.
-Less wear and tear on the tool... When in a high torque situation, and impact drivers motor runs wide open, allowing the fan to cool the motor effectively. Contrast that with a drill driving a screw. The motor doesn't run fast enough to cool the tool as well.
-Stop by your local industrial supplier and get your bits, because the impact driver can destroy bargain brand bits in no time. Also pick up a 3/8" socket adapter so you can use the tool when you work on the car or whatever. I recommend Apex brand bits if you can find them.
-BONUS flourescent lamp... I use it all the time, though I didn't think I would.
Anyway, FWIW, I LOVE mine.
Let us know what you decide
Grant in Iowa
Makita 14.4v combo
