200+ woodworking book reviews
OT Snowblower
OT Snowblower
OT Snowblower
Sawman
>I may have to replace my 24 year old John Deere snow blower. The parts I am in need of are no longer available and it is really starting to show it's age. Runs but not sure it wll make it through the rest of this winter.
So I was looking at Cub Cadet and Husqavana(sp?). Any body have any input?
Thanks
Re: OT Snowblower
Simplicity
Lee Schierer - McKean, PA
>I had a Toro snowblower about the same age that died 3 years ago. I replaced it with a Simplicity 8 Hp machine. Wow, what a difference. I have to be careful with the Simplicity not to put snow up on the roof. It starts on the first pull every time even after 3 years. The only maintenance item I've had is to replace the skids under the auger chute. When I did, I also applied a 1/8" layer of UHMW and I may never have to replace the shoes again. The Simplicity will go through snow to the top of the chute at a slow walk without even laboring. It eats heavy wet snow for breakfast! I clear a 100' driveway with a turn around area and live in Northwest PA where we average over 100" of snow.
Lee
Re: OT Snowblower
Ariens
Bill Earl
>My 14 year old 8hp Ariens still starts on the first pull. In my neighborhood, there are 30 and 40 year old models that are still going strong. Not much has changed in the design over the years aside from paint.
We get about 50" a year. Mostly heavy wet stuff.
Re: OT Snowblower
ebd
Re: Ariens
ebd
>I wholeheartedly agreee with Bill. I'll take Ariens over anything else, Including top of the line Honda machines. Some really great features and built tough.
Re: OT Snowblower
Re: OT Snowblower
Chuck in ND
>I have a Cub Cadet that I bought new I think in 1996, they are made by MTD. It's been a ok unit.
Re: OT Snowblower
Re: Simplicity
Jim Shaver - Oakville, Ont
>A neighbour also has one too Lee.... He loves to show it off, and he's over to do the road drift after the plow goes by often...
If I had a SBr it would be my choice too.
take care.
Jim
Re: OT Snowblower
I have a question Lee
Dustmaker Mike
>you stated "When I did, I also applied a 1/8" layer of UHMW and I may never have to replace the shoes again" How did you attach it was it taped on or riveted or? I guess I am having a hard picturing this in my head.
Stay Warm
Re: OT Snowblower
Re: I have a question Lee
>The shoes are curved and about 1" wide. I drilled and tapped #10-32 holes in the up turned areas on each end of the shoes and then cut a strip of UHMW of the right length and width to cover the shoe. I drilled and countersunk holes at the ends to align with the holes in the steel shoes. I heated the UHMW to about 140-150 degrees (it turns almost clear) and then attached one end with a screw. While the material was still hot, I bent it around the shoe and put in the second screw. They have lasted 1-1/2 winters so far and show almost no wear. The original steel shoes wore through the first winter. I guess my concrete drive way is about a 45-50 grit surface.
Lee
Re: OT Snowblower
Forgot to add...
>The Simplicity is a U.S. made machine......Mine has a Tecumseh engine, but I think they use Briggs now.
Lee
Save your kids jobs, buy U.S.
Re: OT Snowblower
Re: Simplicity
Craig in Silverdale
>Wait a minute. 100 foot driveway, 100" of snow. Does that mean only an inch per foot? lol
Re: OT Snowblower
The only one that works with our snow
Thomas S Stockton
>I posted this earlier but the type of snow we get and the length of our road this is the only option for a snowblower. Why mess around with those little toys when you can have a real machine.
Tom
Re: OT Snowblower
Re: Ariens
Paul Londo
>Good luck finding an Ariens because Tecumseh which makes the engines for their snowblowers has stopped making them and Ariens is trying to find replacement engines so there isn't much production of snowblowers this season.
Re: OT Snowblower
Is That A Tonka Or Hot Wheels???
Ken Oakley-Sunny St. Cloud, Fla.
Re: OT Snowblower
Thanks
Dustmaker Mike
>I might have to look at mine and see if I can do something like that.
Re: OT Snowblower
Here's what you really need
>This snow blower will take care of any snow you get.
Of course you may need your own refinery for the gas it uses.
Lee
Re: OT Snowblower
Re: Ariens
Robert R Clough - Thorncraft
>Paul, I have an Ariens - 2 YO. It has a Briggs.
Re: OT Snowblower
Re: The only one that works with our snow *LINK*
Gary Camp, Bend, oregon
>We have a couple of snow blowers at work, the small one only throws 4,000 tons per hour, the bigger one can move 6,000 tons per hour (100tons per minute. Even then on a heavy snow night they can't keep up, of course the main parking lot is almost 28 acres. If you want the ultimate in walk behind snowblowers check out the Zuagg Snow Beast.
glc
Snow Beast
