A little OT. Need a bolt.
Paul Woolson
>Hi all, I'm looking for an M8 x 1.25 LEFT THREAD bolt in 1.75" length (or whatever the metric equivalent is). I've searched Google and the usual industrial houses (McMaster, J&L, etc) with no luck. Anyone have any leads as to where I can find such a beast?
Thanks in advance. Paul
Re: A little OT. Need a bolt.
Motorcycle repair shop?
>I've seen some funky bolts in my time when working on "Metric-bikes".
Happy Woodworking!
Re: A little OT. Need a bolt. *LINK*
Eddie Pacheco; San Jose, Ca.
>I deal with Mr. Metric and they are very helpful. Here is another source that is also in Silicon Valley that I get fasteners from.
English and Metric Fasteners
Dave Anderson (PacNW)
>Common size---common thread. Have you tried the local hardware store? Also try the auto parts store
Re: Left Hand Thread
GalenV
>Paul
That left hand (LH) thread threw out all the places I know of unless you want a run of 10,000. I even looked for there left hand all thread or studs. Turnbuckles would have one left had thread stub but they are selling a coupling as a turnbuckle!
Odd that left hand thread metric nuts are found easily so not sure what you put them on.
If this is a replacement may need to go back to your parts supplier on your application. If trying something new, good luck.
I own a "metric" Yamaha 1100 but only left hand probably on axles that I can think of. Maybe internal rotating part but have not had to go that far.
May need to have a machine shop cut you at least all thread if they can cut metric. I found no left hand thread metric die as well.
Good luck.
