Mortice chisels
Mortice chisels
Mortice chisels
Hamish
>Are mortice chisels a necessary part of a woodworkers kit? At the moment I have been making them with a router. Would mortice chisels help in the cleaning up process and if so, what size would be recommended. I have also seen swan neck ones advertised that are supposed to help clean up the bottoms. Are they effective?
Hamish
Re: Mortice chisels
Re: Mortice chisels
mckay
>I use mortise chisels when I have 1-4 mortises to make. I have a dedicated PM mortiser, but I can cut mortises faster by hand (vrs. set up of the mortiser) if I have only a few to make. I prefer the Ray Isle chisels.
Re: Mortice chisels
Re: Mortice chisels
Mac in Indy
>Necessary? No. but if you are making mortices with a router your sides should already be pretty good so I assume by cleanup you mean the rounded ends. Here again I make an assumption that you are squaring up the ends of the mortice with a bench chisel or, less likely, a paring chisel. In either case a mortice chisel the same width as the router bit would make the job somewhat easier. Mortice chisels are made for heavy chopping so squaring the corners of a routered mortice is a piece of cake! That said a sharp bench chisel the same width as the router bit will do the same thing just not as easily. Morticing chisels are really only good for mortices (and paint cans) so if you don't have a proper set of bench chisels I'd start there and you'll have chisels for other tasks. If you already have a set of bench chisels then pick up a good mortice chisel sized to match your morticiing router bit and start chopping those ends out!
Check out the Ray Isles morticing chisels. They are the ones I like.
Mac
