Veritas - Innovation in Tools
Ceramic Tile Inlay
Ceramic Tile Inlay
Ceramic Tile Inlay
Jerry Draper
>I am making a coffee table with ceramic tile inlayed in the top. The substrate for the tile will be 1/2 inch plywood. I am concerned that the plywood may bow when the thinset is applied. Should I waterproof the plywood surface or is it necessary?
Anyone have suggestions?
Re: Ceramic Tile Inlay
>Use tile setting mastic to lay the tile. It will be enough of a barrier to prevent the grout from affecting the substrate.
Clint
Justin Szeliga
>The reason a floor doesn't bow, at least not noticeably, when tiled, is that it is at least 3/4" thick, & supported by framing that doesn't deflect very much at all. Perhaps, given that you are using 1/2" ply, & you may not have any other support under the table, dampen the opposite side of the plywood as you mastic the tiles in place. The expansion should counteract itself.
Peace
Justin
Thanks for the replys.
Jerry Draper
