Cedar Plywood
Ron Gricher
>Do they make a 1/4 in. cedar plywood to line a closet with. Thanks
Cedar Plywood
Ron Gricher
Re: Cedar Plywood
Justin Szeliga
>There is a panel made of cedar chips & pine chips, but I've never seen an incense cedar plywood made w/plies. The T&G boards are only 5/16th, as I recall. If you don't mind the look of the chipboard cedar, kinda like OSB going bad, it works very well, I've used it in a couple of closets & have offcuts in my shop that still smell real nice 6 years later.
Peace
Justin
Re: Cedar Plywood
John E in SC
>I think you're going to be stuck with T&G cedar to line a closet with (not that that's a bad thing). I've seen T&G cedar made must for that type of application at the local big box home center, but never seen cedar plywood. As Justin said, I've seen the OSB board with cedar chips, but can't imagine ever using that on any visible surface.
John
Re: Cedar Plywood
Clementine
>I recently posted here about lining a blanket chest with cedar. I have some old 3/4" cedar planks. By the time I would have planed them into nice looking cedar, they would have been too thin to make the box. It was suggested to me to resaw them and then plane them to 1/4", then line the pine plywood box with them. Resawing is new to me, but that is the step I'm at now. Cedar plywood would have been nice, but the Home Depot didn't have it.
Re: Cedar Plywood *LINK*
Dale Lenz
>Did an image search for the cedar you are looking for, it's out there.
Cedar plywood
Thomas S Stockton
>Try woodfinder Macbeath hardwoods in CA has it for about $18 a sheet so it should be availble near you
Tom
http://www.woodfinder.com
Re: Cedar Plywood
Fred Davis
>Aromatic Red Cedar (also known as Eastern Red Cedar) has always been available in the standard plycore thickness's.
In the BlacKHawk community at Danville Ca, we used it in 3/4" plycore for a finish floor in the closets and the 1/4" for lined closet walls.
Incense Cedar is the wood pencils are made of and give pencils their odor which is nothing like Aromatic Red Cedar most are familiar with in Cedar chests.
FredD
Re: Cedar Plywood
mckay
>I go through a unit of 3/4" aromatic cedar every semester with my students. In the west at least we find it without a problem. But then I never purchase lumber of any kind from HD. If you live in the west contact MacBeath Lumber in California or Intermountain Lumber in Salt Lake City or Boise.
