OT: Toothpaste and DVDs
Ed Beck
>The data storage thread made me think of this.
When you rent a movie on a DVD it will frequently skip somewhere and you find yourself at a scene you've already seen (see what I did there). It's even more frustrating because you can't seem to muscle your way through the skip.
Get out some toothpaste (paste, not the gel type). A pea size will do, wet the DVD, and polish it with the toothpaste (the shiny side, not the side with the title). Wash the toothpast off and completely dry the DVD before putting it back into your DVD player.
If I think of it beforehand I'll do this before trying to watch a rental DVD.
Re: OT: Toothpaste and DVDs
Wiping Direction
Bill Howatt
>If you do this and it is a known help for problem disks be sure you wipe radially out from the center to the edge. Do NOT wipe it in a circular direction around the DVD or CD (if the fine abrasive lines happen to "follow" a track then there could be too many errors for the error-correction to handle).
Bill
Re: Wiping Direction
Alexander Grigoriev
>Considering that the laser beam takes a spot about 1 mm on the surface (numeric aperture about 1), any little scratches are so out of focus that it doesn't matter.
Stuart Hough
>I've always used a Bounty towel and alcohol. The alcohol weems to slightly melt the plastic and smooth over the scratch, and the Bounty towel dries the alcohol up quickly. Why Bounty? Because it is made without using wood products, so no microscopic chip to scratch with.
Bill Howatt
>Its not the focus or trying to read the scratch, it apparently is a beam/reflected light dispersal problem. This isn't my bright idea about wiping direction but is very frequently stated on DVD/CD sites.
Bill
Alexander Grigoriev
>I doubt that the wiping (isopropil) alcohol affects (softens) the CD's polycarbonate. It's recommended for wiping eyeglasses, which are also polycarbonate. Solvents that work on plastic tend to fog it.
E. Taylor
>That appears to be basically what the video rental places do. I rented a DVD the other day and the clerk eye-balled the shiny side and then put it in a machine. He squirted some thick liquid on it (looked like liquid rubbing compound) , closed the lid and turned it on for a minute or two. He said that they do it all the time as a high per cent of the discs come back with scratches.
