Spiral trim bit...WOW!!!
Ralph Turney in Huntington Beach
>I just wanted to say thanks for the help in choosing between a straight trim bit and a solid carbide spiral trim bit. I have had a straight bit lying around that I bought many years ago and had never used, but wanted to keep the noise down in my condo complex. So with the advice of some of the member here, I plunked down the money and bought a 2" spiral trim bit from Whiteside and the difference was astounding. Not only was the spiral very quiet compared to the straight bit, but it also cut like butta. Except for a couple of gaffs on my part the cut that the spiral bit made in direct comparison to the straight bit was VERY noticeable better. So, if you need a template trim bit for 8/4 material, I believe that the spiral bit is the only way to go.
Thanks!!!
Ralph
