200+ woodworking book reviews
Under Stairs Storage
Jerry Huey
>Looking for your help.
I have searched for under stair shop storage ideas with very little success. The stair closet opens from the rear. Just trying to maximize the space. Any ideas?
Thanks,
Jerry
Re: Under Stairs Storage
Big Drawers One Tread Deep
Tom MacGregor
oops! that's riser, not tread...
Tom MacGregor
GalenV
>Helps if you have some idea of what you want to store and since you say door at back of stairs how much room behind stairs to a wall. Could be shelves but you will want to only go back so deep. Drawers or slide out shelves are more work but may bring back items forward. The amount you can pull out is depending on how much clear space outside of door.
If you wanted a deep bin to go back into stairs you could make a caster box and pull out but have to have room outside of door to do that. Could be a mix of bin, shelves and drawers.
Maybe you just want a vertical rack with same slope as stairs that can be rolled out so entire unit is out for access to shelves by side.
Again what are you trying to store?
Just nothing that could be a fire hazard and cut off stairs as exit!
Nathan
>Hi Jerry:
We have a similar storage area in the basement under the staircase that leads to the basement. Access is from the back, like a closet with a ceiling that slopes steeply downwards towards the back "wall" of the closet (in our case there is a low wall at the back). One way to utilize this space is to put in shelving along both side walls. Just make the shelving narrow enough for a person to squeeze in between the shelves. If it's a really narrow staircase you could still have shelving on just one side.
Hope this helps.
Nathan
Ed Mulligan, Cape Cod
>How about a cart with shelves that fits into the space, i.e. sloped front edge. For access you would roll out the whole thing.
Another idea: a lazy susan type shelf system like you find in kitchen corner cabinets. Not as efficient but more accessible.
