drying wood
drying wood
Jim Orasky
drying wood
Jim Orasky
>Recently purchased a few turning blanks on ebay. Several of them are green wood coated in wax. Sizes run about 2x2x12. Wood is pistachio.
I do not want to turn them green, should I remove the wax to let the blanks dry?
Re: drying wood
Re: drying wood
John Veerkamp, Western Mo
>If you remove the sealcoat, likely they'll crack & split. the purpose of the coat is to slow drying to prevent disasterous movement. The coat also will seal out oxygen and should prevent moulding. The molds that cause staining need oxygen to thrive.
John
Re: drying wood
you will need specific advice
Bill Tindall, E.TN
>Some exotic woods are very difficult to dry without checking. Such woods may be very dense. Others, while not very dense, have huge tangential to radial shrinkage ratios and they are also problematic, plum for example. Success, or not, will also depend on the details of how it was cut from the tree. I don't know about this wood, but be wary of drying it too fast until you can get advice from someone with actual experience drying it.
It has been my limited experience that if it is sold in wax, it has drying issues.
You might try asking the person you bought it from.
Re: drying wood
Lee Grindinger
A pithy issue
Lee Grindinger
>If the pith is present in your blanks it's unlikely you'll be able to dry them well, if the pith is not present your chances are much, much better, plan on two years because pistachio is a slow one to dry without checking. Leave the wax on the ends, clean it from the sides and dry it very slowly out of drafts, watch it carefully for any surface checking which will indicate it's drying too quickly. Don't sweat a little mold, it's only skin deep. Mold stops at 18% MC, fibre saturation point is around 28% MC. The key is to go slow.
Re: drying wood
Jim Orasky
Re: A pithy issue
Jim Orasky
>Thanks for the advice - These blanks have no pith.
I'll put it away and keep an eye on it.
Re: drying wood
Re: A pithy issue
>2" diameter are much easier to dry than the thicker stuff.
What are you going to make? If I have a specific use in mind, I sometimes turn such blanks round and possibly reduce their diameter so they dry a lot faster with less stress and less chance of cracking. Rewax the ends after rounding.
If making small goblets, for example, you can rough them out just like you would a bowl. If making boxes (usually from larger diameter, though) I rough turn both sections and let the pieces dry and stabilize for a few months - they rarely crack. Mike Stafford just mentioned he soaks roughed box blanks in alcohol for a few days before drying.
You might also ask this on the Turning side.
