OT What to do for cracked fingertips??
>I try not to post too much OT stuff here, but I've got several fingertips that are cracked so badly that I can hardly type, and in my job, that's a real problem. Crazy Glue seems to work pretty well, but it's sticky and crusty and I'm not sure it encourages healing. I was wondering if there is anything else I should try. Do any of those lotions or emollients do any good? NuSkin? I've gotta address this somehow.
Re: OT What to do for cracked fingertips??
Corn Husker Lotion
Dustmaker Mike
>I use Corn husker lotion on cracked hands all the time after doing concrete work or fishing in the cold NW my hands would crack. It does a great job. You can get it at any drug store. I have used it for years and used to keep a bottle with me all the time. Now there is a bottle in my medicine cabinet just in case I have to do some real work.
Best part it is cheap and it really works fast.
Now that I am flying a desk I don't seem to need it as often as when I was doing construction.
Ditto,ditto,ditto,ditto,ditto! I could go on.
Art Silva
Re: Corn Husker Lotion
Tony - Memphis
>I've been meaning to try that. I really like the GoldBond hand cream products.
Funny, I had to get fingerprinted to get security clearance (sometimes, I have to be close to airplanes). They were using digital scanner finger printing machines. Each station had a bottle of Corn husker stuff next to it. The had to soak my hands in it to get a good reading. Must be something to it.
Tony
Bert's Bee Salve and Bag Balm
Scott in Montana
>Although I've never had dry cracked hands, an employee of mine really suffered through our dry winters to the point his hands would bleed. He used two different products. He used Burt's Bee's Salve, and the old agricultural cure-all, Bag Balm.
If I recall correctly he would apply large quantities of Bag Balm at night and sleep with his hands in a pair of socks. Then he would use the Burt's product to get him through the day.
Hope you are able to find something that gives you relief.
Scott in Montana
My wife loves Bag Balm
Yonak
Try this..
John E in SC
>At bedtime, rub plain vaseline in well, then put a pair of cheap cotton gardening gloves (or socks) on. Usually works pretty well. Avoid hot water or any prolonged water exposure. Use alcohol gels rather than soap and water to wash your hands when possible.
HTH,
John
(I'm an MD, but not a dermatologist. I wash my hands a jillion times a day and have the same problem, so this is what I do.) Haven't heard of corn husker lotion, but would like to give it a try!
Jesper, Denmark
Re: Bag Balm...........
Jesper, Denmark
>Even though it is intended for the teats, not the udder.
Maybe allergy, try cortisone
JohnM in mid Mich
>Ellis:
Every time I get heavy into a project (I'm a hobbyist) I eventually get this deep split on my thumb along the thumbnail. I recently observed that, curiously, it seemed to happen whenever I started sanding. I wondered if maybe I was having some allergy-like reaction, rather than simple dryness, so over this holiday I tried some 1% Cortisone cream as soon as I had the first signs. AND IT WORKED. I've now successfully avoided the splits twice by this method, although that is admittedly very limited data, and decidedly unscientific. Your description sounds like this. Give it a try.
John
Interesting
>I think I have some around here. Also, I noticed that the cracks appeared when I was in my Christmas countdown binge in the shop, sanding bowls and bottle stoppers and such. Also, wiping on finishes (without gloves, mea culpa) and wiping my hands on naptha soaked towels doesn't help, I'm sure.
Thanks for the tip.
:-) I can just picture me....
>... balming and bagging my hands at night. What's that stuff smell like anyhow? I've seen it at the local feed store but never took much notice.
And, the salve rings a bell, too. I try to avoid greasy stuff when I'm working in the shop though. It tends to put grease marks on things.
Thanks for the tip. If it works, it's worth it.
Brent Smith, Montreal
>I used to have the same problem, they cracked so bad they bled. The last few years I've been using Nexcare for cracked finger tips. It's a liquid that comes in a very small bottle. Just make sure you let it dry on your finger tips for a few minutes. A few times a day I use Gold Bond Ultimate Care, it's about the only product I've found that prevents the cracks in the first place.
12% Ammonium Lactate Rx only
Re: Interesting
JohnM in mid Mich
>You just described my scenario precisely. Mea culpa, too. I also suspect a contribution from long years of careless abuse: acetone cleanup after fiberglassing kayaks, washing tar off the hands with gasoline, etc. Imagine my internal organs, brain tissues, etc. It is a wonder I have any brain left, considering these and other youthful indiscretions.
J.
John Pappas
>I got some Badger Healing Balm from Lee Valley that has worked well for me. It is made up of Olive Oil, Natural Beeswax, Castor Oil, Aloe Vera Extract, and Essential Oil of Sweet Birch. I've since seen it in a health food store.
1000-2000 IU Vitamin D/ day
Dave Bair, Eaton Rapids, MI
Farmer's Friend and cotton gloves *LINK*
>I get the hand salve at a local market. I put it on and then have the LOML put plain white cotton gloves on my hands. I wear them at night when my hands get really dry and cracked.
Other hand salves would also work. The important thing is the cheap white cotton gloves. They keep the salve from rubbing off on the sheets and they keep the salve in constant contact with your hands.
My $0.02.
Burt's Bees
Re: 1000-2000 IU Vitamin D/ day
>I'm already taking 5,000 IU of vitamin D per day (5 days per week, mostly in winter and spring) on the advice of my doctor. I hadn't realized that it was beneficial for dried out skin.
Thanks
I've had luck
DizD
>healing cracks using the Band-Aid Activ.Flex Bandages - these are the ones designed for use for long periods of time. You don't use antibiotics or lotions of any kind under these - just clean it up and apply with skin dry. Of course they're designed for flat areas (blisters, etc), but with some creative scisssor work I've been able to get fairly good results on fingertips. I buy the large size and make radial cuts up to and into the pad area, then press the resulting triangles down, overlaping as you go around. They're supposed to be waterproof seal and I generally get 2 days or so before they peal up at edges. I try to keep any cracks covered with some type band aid until healed and then use stuff to keep cracks from reoccuring.
Dale Lenz
Re: Fourth Corn Husker's, Ellis.
Dale Lenz
>Use about 3-4 times a day for 2-3 days and my cracks are gone. Can work wood 4-5 minutes after rubbing it on.
Re: :-) I can just picture me....
Ken Oakley-Sunny St. Cloud, Fla.
>Put it on your fingers and it sure will stop you from pickin your nose. Smells kinda like rotten cow manure. But it works.
I have used Corn Huskers and Bag Balm and Bag Balm is my favorite.
Paul Kramer
This is what I do too. . . it works for me
Paul Kramer
Fred Davis
>Ellis ,
cracked finger tips in dry winter weather are the bain of bowlers like myself and most of us have tried all of the traditional fixes and the ones that seem to work best for me are, New Skin which also kills the pain and at night , I break open a capsule of Vitamin E and pour some of the oil into the crack .
Works for me, I just treated my cracked thumb prior to bowling tonight.
FredD
Working Hands Creme
Gary Camp, Bend, Oregon
>A local pharmacist concocted the stuff for her fathers cracked hands. It sure works for me, though I usually use it on cracked feet. Lots of hardware stores in your area carry it.
No affiliation
glc
Re: lanolin
Mike Hamilton
>Hi Ellis,
I used to buy 'hydrous lanolin' from the local drugstore. A tube would last for years. Last time I needed some, the pharmacist scratched his head then led me to the 'baby stuff' aisle. The only lanolin they had was a product called 'For Breastfeeding Mothers' by Lansinoh. It's pure lanolin. Just a tiny drop on each crack, let body temp melt it for a second or two, then rub it in - it works wonders.
Regards,
Mike
