Grand daughter Christmas Present
Lee Schierer - McKean, PA
>This is a cherry and maple jewelry box I made for my grand daughter as a Christmas present . The three trays are removable and when removed expose a larger divided compartment below. The center partition of the lower compartment is removable if desired. The wood is all natural color with a clear semi-gloss lacquer finish.
The box is made from pieces of 3/4 x 5-1/2 cherry crown molding. The only tools needed to make the box were a router and a TS. Cut the crown molding to lengths needed with the TS set on a 45 degree bevel cut. To make good corner joints this 45 degree cut needs to be exact and opposite sides have to be exactly the same length. This box is about 10 x 15 x 6 outside 8 x 13 x 4 inside. Once the sides pieces are cut, cut a groove near the bottom for the bottom board of the box. Cut out the bottom board and the top and you are one on the TS.
To form the leg cut outs, I made a jig for use on my router table with a guide bushing and 3/8" dia up spiral router bit. The jig guides the cut and insures the height of the cutout is all the same and finished quality. You could also use a bandsaw, but would have to do a lot of sanding to get rid of the teeth marks. I attach the pieces to my jig with double sided tape. Once the legs cutouts are done, I glue up the box. On the assembled box and lid, I mark the locations of the two brass cylinder hinges. This has to be very precise so the hinges will press into the holes. There is no adjustment on this type of hinge. I drill the holes to the desired depth on my drill press. Then after the holes are done, I put a 45 degree chamfering bit in the router and set the fence to remove material from the top edge of the box and back lower edge of the top until the bevel is halfway across the hinge holes. I shim up the front edge of the lid about 1/16-1/8" so that the bevel on the back side ends up at about 47 degrees so the lid leans back slightly when fully open and stays open more readily.
A trial assembly verifies the hinge fit and function then its off to finishing. For final assembly I line the hinge holes with superglue right before pressing in the hinges. This glue insures the hinges stay put better. That's pretty much it for the box.
The trays are straight forward except for making the thin stock. The tray corners joints are locking rabbet joints cut on the TS. For 1/4" stock the 1/8" saw kerf is ideal for making this joint which almost doesn't require glue.
Thanks for viewing,
Lee
Re: Grand daughter Christmas Present
Beautiful!
>That will be around for generations.
Clint
Dale Lenz
Re: Very Nice, indeed!
Dale Lenz
Jennifer@Indy.USA
>Lee this is really nice. Your Grandaughter will treasure it forever. What a beautiful gift.
Jen
Charlie Self
>Superb job. You must have one happy granddaughter.
Don't let my wife see that
>She's been waiting for 30 years for a jewelry box. :-)
Seriously, Lee, that is really a nice looking piece of work. Two questions: I read your description of the hinge arrangement, but I can't totally understand it. Could you post a closeup of the hinges? Also, I was wondering about what kind of material you used for the padding. Is that velvet stretched over cardboard? I'm always curious as to how different folks handle these details.
Thanks for showing it.
Re: Don't let my wife see that
>Since I no longer have the box, I can't take photos of those hinges. Here's a photo from the Rockler site.
and another one of a different jewelry box showing he hinges:
The padding in this box is a stiff felt material I picked up at a local craft store. I cut it to size and then mount it with spray 3M adhesive. I mask the sides of the trays or box with painters tape to keep the spray adhesive off the walls. It isn't as fancy as strecthed velvet, but it seems to work okay.
Lee
>Good Afternoon Lee,
You did an excellent job designing and making that box. She will treasure it for years, and for good reason. I am partial to cherry finished as you did it, and the intensity of the blue fabric color sets the cherry off to finest advantage.
George
Keeth Miller
>Hi Lee,
That is an absolute beautiful piece. You should be very proud of it.
Please describe the finishing techniques that you used. Materials and steps taken, for example.
At present, I am designing/building a Cherry Tea Chest for my Sister and would love for it to be at least half as pretty as your Jewelry Box.
Keeth Miller
>I sand all cherry parts with 220 grit paper. I wipe them down with a dust free cloth and in this case sprayed on a light coat of Clear Lacquer. Once the lacquer dried, I resanded every thing to get a smooth surface. The second coat was sprayed and sanded the same way except I used 320 grit paper. I applied a total of about 6 coats. Since I was able to get the final coats of finish on without any dust nibs, I didn't sadn or buff out the final coats.
Lee
Brandon Mclean
>Very very nice work! I bet she loved it!
kaleb
>Very Very Nice! Bet she really enjoyed this
brandon mclean
>LOL>. I agree! But dont let my daughter see it..
Brandon
