How to make dining table with leaves
Bill Tindall, E.TN
>Daughter wants a dining table, square with rounded corners, that can be extended in length by the addition of leaves. What are the options for constructing a table that can be extended? It would seem that it would call for some sort of hardware enabling it to be pulled apart and leaves inserted, but I have never seen for sale what ever might be required.
Re: How to make dining table with leaves
Lotsa options out there
>...from entirely wooden mechanisms to fairly sophisticated rack and pinion style mechanisms. They come in different extension lengths and weight capacities, too. Depending on your base design, you can custom engineer a solution for this table alone. I once made one using impregnated "wear strips" (I believe Arguto was the name -- they make bearings for conveyor belts and such) to provide an effortless action.
I know there are a couple brands of mechanism that are top rated, but I couldn't tell you what they are without doing the homework.
Table slides
>Rockler sell some brands http://www.rockler.com/CategoryView.cfm?Cat_ID=146\
Lee Valley also sells some http://www.leevalley.com/hardware/page.aspx?c=2&cat=3,43614&p=43621
There are lots of them out there.
Re: Table slides
Ed Mulligan, Cape Cod
>There are other options: the draw-leaf where leaves pull out from under the table ends, and the flip -top where the leaf is stored in the table and rotates into position when the ends are pulled apart. See Encyclopedia of Furniture Making for details.
Another option is to have a separate table or tables which fit between the ends when needed. The ends are two pedestal tables. This was popular during the Federal period.
Re: How to make dining table with leaves *LINK*
Jim Dillon
>Bill,
Jerry Work's large manual on using the Festool Domino contains a lengthy description of making a table with leaves using a mechanical mechanism IIRC. Naturally, you don't need a Domino, but if you need the excuse... 8-). Anyway, his description is quite nice and may be helpful. The PDF file is roughly 7.5MB.
Jim
Domino Constructed Leaf Table
Use wood, it's much stronger :)
Thomas S Stockton
>Bill
I usually use Waterloo brand metal slides. They are fairly ugly being made out of steel but they are really strong and do not flex at all. I was pretty conflicted when I started using them but every client I gave the choice between these and making wooden ones choose the metal ones. For tables that don't have a deep enough apron to hide the slides you can you can make decorative elements to hide them.
Tom
Watertown not Waterloo
Thomas S Stockton
LOL! That's bad Mark, really bad! 8-)
Jim Dillon
Garrett in Victoria
>Hi Bill
When I extended our dining room table last year, I had to make new extension slides. I copied the existing wooden ones, and it was surprisingly easy to do. If you'd like, I'll take some photos and write up a how-to.
Cheers, Garrett
Re: How to make dining table with leaves *Pics*
Garrett in Victoria
>Forgot to mention, that I also made a couple of leaves with aprons to match the existing, so I can elaborate on that too, if it would help.
Cheers, Garrett
maybe not
Tom Sontag - St. Louis
>A tree service guy was repairing a chipper as I approached one day. I suggested that maybe it was still good for mulching leaves. His reply was that leaves wore his blades out faster than branches did, leaving the metal very shiney from the abrasion. Leaves are tough little buggers. I am thinking that laminated leaves could be very strong indeed.
Still, I'd use wood too.
Tony - Memphis
>There was an article about that in FWW recently I think? I know I saw one somewhere.
Tony
Taunton Press published a book *LINK*
Frank Mutchler
>"Dining Tables", by Kim Carleton Graves & Masha Zager that may have just what you're looking for. Look on page 72 for the plans to an expanding rectangular table including how to make the sliding extensions
It would not be too difficult to modify the design with rounded corners but if you want more than just 'rounded', there are also plans for an expanding racetrack oval table on pg. 89.
You can find it on Amazon for less than $15.00 by following the link. Beautiful photography, very clear detailed plans, and close up shots of the more challenging tasks.
Dining Tables
FWW #65 and #182
Tony - Memphis
Thanks all,.....most helpful
Bill Tindall, E.TN
