to sticker or not to sticker
Kelly Anderson
>I have some Ash that I have had for 3-4 years stored inside, unheated/cooled shed, stickered. I have not had any problems with movement in anything that I have built with it so I am going to assume that it is dry, or at least as dry as it is going to get. My question is dose it need to be stickered? If I remove the stickers I can store it in half the space it is in now and make some room for other wood.
Re: to sticker or not to sticker
Grant in Iowa
>So long as there has been no huge change in humidity, such as moving to another part of the country or something, you are fine removing the stickers.
In fact, I'd say you waited about 3 times longer than necessary for 1" thick lumber
Regards,
Grant in Iowa
commercial practice
Bill Tindall, E.TN
>As soon as lumber is dried to a target moisture content it is dead packed for the reasons you state, plus others. Personally, I often skip plane it first so it stacks better.
Bugs are especially fond of ash lumber, more so than anything I have ever stored. Watch it for piles of fine dust. If you see such, your lumber was bored full of holes some time earlier.
Skip plane?
>What is skip planing and how does it differ from regular planing?
Re: Skip plane?
Grant in Iowa
>Skip plane is a process of planing rough sawn lumber so it stacks better and so you can see the grain of the boards for easier project selection.
Note that rough sawn lumber is generally not straight and needs to be face jointed before final use. So you run it through a planer, taking a light pass off of each side. This will clean off high spots only most times, but will allow you to sort the lumber easier later for color, grain match, and quality.
The idea is to simply clean it up a bit for easier use and stacking. Note that you don't want to take too much off, or you may find later that after face jointing and planing you have wood that is too thin.
For example, if I have lumber that was rough sawn to "finish out at 4/4", then I might skip plane it an eighth or more over that. You want to leave as much thickness as possible while exposing some grain and making it close to flat for storage.
FWIW,
Grant in Iowa,<----works with rough sawn lumber from small local mills almost exclusively.
Thanks
Kelly Anderson
