Fogged Glasses
Fogged Glasses
Fogged Glasses
Jack Putnam
>How can you get rid of fog on prescription glasses when wareing a dust mask and using a table saw? This can be very dangerous...
Re: Fogged Glasses
Been there, done that
Neal in San Jose
>I would recommend a two-pronged approach. I'm guessing you are wearing the paper disposable type masks, since that's kind I've had problems with. I've never been able to get a good enough seal around the edge to keep 100% of the dust out of my nose and I always get fogging of my glasses, so I've given up on the paper ones and gone to a good quality half face mask. There are several good ones on the market, and the individual fit is critical to success, so try several in stores or at friends' to find one that fits you well. Mine is a 3M, but it may not fit you well at all. There was a discussion on this board about a week ago on the subject of half face masks, so you might try a search on that subject for brands that others have had success with. Remember that the oils in some woods like walnut can also cause reactions in some people, so get one that is effective aginst more than just dust and keep it in an airtight container when not in use.
Another approach is a powered dust mask, but I don't have any experience with them, and hope that someone else will chime in on that part of a solution.
Second, improve the dust collection on your saw (and your whole shop for that matter). It is much easier to control the dust at the source than to deal with it once it escapes into the shop air. This could reduce the need for you to wear a dust mask at all, at least for woods you don't currently have reactions to. Just remember that sensitivity can build up over time and exposure and use the mask more rather than less.
A third possible approach would be to use more hand tools and fewer powered tools. They tend to generate chips and shavings rather than dust, which are much less of a breating/sensitivity problem.
Re: Fogged Glasses
Re: Fogged Glasses *LINK*
Ed Mulligan, Cape Cod
>I use the kind with an exhale valve. On the right in the link photo.
Mask with exhale valve
Re: Fogged Glasses
Re: Been there, done that
Ronald from NW Ohio
>buy a respirator there not that much and they do the job.
Re: Fogged Glasses
Re: Fogged Glasses
Alex Grigoriev
>Use a mask with exaust valve (flap). I use 3M P95. 10 pack costs about $26.
Re: Fogged Glasses
Don't exhale!!!
Lee Schierer - McKean, PA
>Just kidding. The 3M masks worked for me much better than even the valved paper masks. They also make a flat mask like a surgeon would wear that seals better. I wouldn't recommend any of the antifog sprays for glasses as most I ever tried didn't work well and made the glasses hard to clean.
I never tried it, but you might want to try some of the double sided tape women are using to hold straps and parts of dresses in place across the bridge of your nose and stick the mask down tighter.
Lee
Re: Fogged Glasses
Fogged Glasses in the OR
Jim Follette...Fayetteville,NY
>Having had to wear surgical masks almost every day of my working career my glasses occasionally fogged. Most had skinny moldable strips at the top but these worked so so. Usually I just put a strip of tape along the top of the mask and stuck it to the bridge of my nose.
Re: Fogged Glasses
Re: Fogged Glasses
Fred Davis
>I have never tried it , but have read several times, that wiping your glasses with a sheet of Fabric softner wil prevent fogging.
FreD
