Help with wooden hinges?
>I have a post from a day or two ago about wooden hinges. I solved the problem with the brass rod by buying a number 30 drill bit. That worked well except that the bit had a regular point and it wandered, so I drilled all the holes with a 1/8 split point and then enlarged them with the slightly larger drill.
I probably should have tried some of the suggestions for turning rod itself into a reamer.
My lady friend was disappointed with brass pins. Thought I should be using wooden pins in wooden hinges. What's your thought on wooden hinge pins?
Started the process by Googling "making Ebony hinges". The guy has a great PDF on it. His were at about half the scale of mine, being 3.2 mm thick with a 2mm pin. Mine are 3/8 thick with a 1/8 pin. I tried rounding the with a patterning bit as suggested, but because mine were larger the bit I had was not tall enough. So I sanded them into submission with a drum sander and a pattern block. Worked well and much less intimidating that the router technique.
Another question. There is no discussion on his site about how to fix the pins in the hinges. Any suggestions?
Been working on this for two days and have made what looks like parts for 16 pairs of hinges in various woods. Got two more pair that I ruined when the bit drifted. Have to cut those off and redo the fingers and redrill them, so all is not lost.
