On the utility of owning number drills
Bill Tindall, E.TN
>Number drills are metal drilling bits that fill in the gaps of diameters between 0 and 1/4" not occupied by the fractional drill sizes. They are numbered 1-80 in decreasing size and they can be bought in sets of 1-60 and 61-80. It is a good bet that between the fractional drills and number drills one can drill a hole within 0.003", or less, of any diameter one chooses/needs.
I find them indispensable for woodwork. Take a recent example. I was installing Accuride drawer slides with flat head "sheet metal" screws. I used miscellaneous wood for the drawer sides and case so the screws were penetrating wood from oak to poplar in hardness.
With my digital caliper I measured the total diameter of the screw at 0.163" and the shank diameter (total diameter less threads) at 0.117". So ideally the pilot hole would be drilled 0.117" and it was a simple matter to find a number drill of this diameter. This diameter worked perfect for the softer woods. However, the oak was too hard for the entire thread depth to cut into it so the 0.117" pilot was too small. Using a scrap it was easy to find the right diameter for the oak pilot holes by trial and error. I use the same process to drill pilot holes for nails and brads. When installing hardwood trim I typically have three hand drills with number drills ideal for 16 ga. brads, #3 and #6 or 8 finish nails. The advantage is no split wood or bent nails because the pilot hole is too small.
If you only own a set of fraction drills the steps between sizes is too large to select a drill ideally suited for pilot holes. The result is too often wrung off screws or stripped slots. Ditto for brads and nails except here the bad result is too loose, bent nails or a split piece.
There are "letter drills" that fill the gaps in the fractional drills from 1/4 to 1/2" but I use these less. One handy use for them is fitting round tenons such as might be made on a lathe. I have a bad time hitting 3/8" exactly for example. Doesn't matter as some letter drill will match the actual tenon diameter.
