Bill Tindall - OK I made my sled, got questions
Ed Beck
>Bill - I followed your advice and am building a sled that rides in both runners. I bought metal runners and attached them to 3/4" shop plywood (7-ply, birch veneered). I've got a piece of 5/4 ash that I routed over to make it comfy on my hands, glued to the plywood using Titebond III (that took a lot of time, making sure it was square).
A few questions.
1. I had what I thought was a good idea. My fence runs the full width of my sled (44") and has a blade guard on it. When I started to make the front blade guard I though, what if I make a back fence the full length also, then make a piece that I can put between the two fences. The purpose of this would be to have a fence that I could use for small (non-crosscutting) jobs. For example, cutting the lid off of a box. One might also be able to clamp the working piece to this fence as another way to keep your hands away from the blade. Good idea or bad?
2. Do I need to add some screws to the fence? I was planning on adding a few 2 1/2" #8 screws to each side of the fence. Is this overkill?
3. What about finishing? What do you typically use for this application? Something hard I would think.
4. Any opinions on what type of wax to use on the table saw and the sled? Or is this question going to start a religious war?
Thanks for all your help, I just hope that this thing cuts square, I'll find out tonight.
