shaper fence
Bill Sams
>Yesterday I built this shaper fence with sliding dovetail gibs that is modeled after a Felder design.
the pics should be self explanatory to a large degree. Essentially 2 pcs quartersawn poplar milled to 1-1/8" x 6" x 20" with dovetailed grooves, with recessed holes below the grooves which accept the bolts which fasten it to the cast iron fence of the shaper.
the gibs were made using the another pc of poplar with the same dimension, using the same router bit, but adjusted the spacing so the gibs would fit the grooves. These gibs were milled on both sides of the board, then resawed on the bandsaw slightly higher than the actual fence height. The hand planing the gibs level with the surface.
the whole point is to eliminate the tendency of stock wanting to "cave" in towards the cutter while milling by having at least a small bit continuous fence. The gibs slide to any position and can be fastened with small drawer slide screws if necessary
Hope all that makes sense.
