OT Kill-O-Watt
Sawman
>Anyone have one of these?
OT Kill-O-Watt
Sawman
Re: Yep - why?
Dave Mount
Re: Yep - why?
Sawman
>How are you using it? Worth the price?
Re: OT Kill-O-Watt
Lee Schierer - McKean, PA
>From what I read, all it does is measure the power actually being used. You can get the same information from the product label of any appliance. It seems the device will also allow you to put in your local electrical cost and the readout will be in $$ instead of KW and it will keep track of the total power used through it over time. I fail to see how it will save any power or do anything except lighten your wallet by $40.
I would think you would be better off investing the $40 in a new router bit.
Just my 1 KWH worth.
Lee
Re: OT Kill-O-Watt
Marvin Horn
>Bought one several years ago to do a survey on my house's electrical useage. Paid for itself when I figured out that a new $2000 "energy efficient" refrigerator had the potential to save me $20-30/yr. Needless to say I still have my old refrigerator and my $2000. Actually I spent the money on tools and wood.
Since then I use it as an ampmeter on my 16-32 drum sander which is prone to kicking out on overload. I can virtually eliminate kickouts by watching the amp load closely. Still have it available for the occasional load useage reading.
Re: OT Kill-O-Watt
Bill Howatt
>I made one myself. I made a current sensing transformer from an old PC power supply transformer which turned on a transistor when the device under test was running. The transistor caused a battery powered wall clock to run. I measured the actual current used with a clip-on ammeter. After I measured a couple of things it became useless but I plan to modify it to turn on my shop-vac when the miter-saw is turned on.
Like it was said, you can get a lot of the same info from the appliance's panel. The way to save and have a real life at the same time is to use the power when you need it and be sure to turn off things when you don't need them. No matter how much you measure, if you use it, it will cost you some money. Living in misery to save a little money isn't my idea of what life is about. If I thought that, I would be using only hand-tools and a spring-pole lathe.
Bill
Re: OT Kill-O-Watt
Marvin Horn
>See post below. I found that few appliances actually draw nameplate amps, the exception being incadecent bulbs which tend to be dead on. Most are intermittent loads such as the refrigerator. When I bought the Kill-O-Watt, it was part of a campaign to get my electrical useage down. I lowered my average bill by 20% with an investment of $300 or so but I still spent my $2000 on tools. In my case it was a great investment.
Mine measures watts, volts, amps,volt-amps, and killowatt-hours.
Made a great 120 v ampmeter.
Re: OT Kill-O-Watt
John McGaw
>Not really. An appliance, computer, etc. uses a variable amount of power depending on what it is doing. A nameplate rating may be good for the maximum permissible power but does not relate well to the actual usage.
Nope. Mine's From Brand Electronics
John McGaw
>I've got a small unit from Brand Electronics that was purchased before the Kill-O-Watt existed. It measures instantaneous power, cumulative power, and usage $ cost based on local rates. Pretty useful, at least for a while, but once you've measured everything measurable it gathers dust until a new power-using toy comes along. I believe that mine does everything the Kill-O-Watt does and only cost me twice as much...
Even so
>Even if the useage is variable, you can't change what it consumes unless you turn it off and then it doesn't serve any purpose to have the appliance. Knowing that an appliance used X KWH over a Y week period doesn't tell you anything unless you have the replacement subjected to the same operating conditions at the same time. Knowing my microwave uses more KW when I run it won't stop me from using it to heat up dinner.
Lee
Re: Even so
John McGaw
>Knowing consumption under "real" conditions allows one to evaluate where the dollars are going. If you don't know which appliances/devices are using the most power then you have no way to prioritize changes in your practices. If you don't know which appliances/devices are using the most power you have no way to even begin thinking about replacement/repair as a saving strategy.
Knowing the nameplate power rating of a device gives no guidance at all in the real world. I have a computer which, by ratings, consumes 500+W. It actually uses 170-175W while running over the long term; It uses about 1W while sleeping. Should I consider it a 500W, a 173W, or a 1W device when evaluating how I use it? Should I cause it to sleep automatically when I walk away or should I allow it to continue running what I see as an important background task? Only by being informed can I make a rational decision.
Re: OT Kill-O-Watt
Mike Fitterling
>My boss uses one, but I am not sure it is the same brand. From the descriptions I have read it sounds so. He uses it to compare usage to output from his 7.5 Kw solar array. Not a typical application.
