Hidden IR (remote control) system *LINK*
Brian
>I am building a built-in bookcase that will bury my Audio/Video components behind wooden doors. Do these things work for multiple remote controls? Is a particular type better in your experience?
Thank you.
Smarthome Hidden IR
Re: Hidden IR (remote control) system *LINK*
David Hay @ Denver
>I have the system below, though I didn't get it from Rockler. They sell systems that are shielded from Plasma and Florescent (LCD), but I haven't found that necessary. I have the receiver right under my LCD TV and it picks up all of my remotes, though it does flash the light a bit when the TV first turns on.
David
Xantech IR Hidden Link Kit
Brian
>Thanks David. Will these accept remote signals from an angle or do they require a straight shot?
David Hay @ Denver
>I haven't noticed any issues with it not working at certain angles. My wife will routinely sit next to the TV (where we have a computer nook) and run things with the remote nearly parallel to the receiver face. The only time I've had problems is when I have the remote too low...but that's because the receiver is blocked by the edge of the cabinet countertop (the TV and receiver are set back a bit from the edge).
David
Dick Mahany, Morgan Hill CA
>I built an entertainment center several years back and used the parts from Rockler. It works nicely. Am controlling a Dish receiver, Denon AV reveiver, Panasonic DVD all without issue. Works with individual remotes as well as a Logitech universal remote. I have the "eye" mounted directly in a decorative moulding directly atop a plasma TV with no problem. The eye works from a relatively wide angle and has a green talk-back LED that lets you know it is receiveng the IR signals.
