Bathroom Fooring Update and Finish Question
>I back to my "day job" from my Holiday break. And frankly, I could use some time sitting on my arss. Spent the last 10 days remodeling the upstairs including an all new master bathroom. Made good progress but have much to do still.
You may remember my question post a while back about tongue and groove router bits. I ended up buying a set of Whitesides. So I went about milling about 110 sf of Curly Ambrosia Maple from rough sawn stock.
I don't have a shaper...rarely would ever use one. But folks, milling flooring in a small shop and using a router table is a chore. None the less, mission accomplished.
So last week I installed the floor. Generally it came in well despite a few small gaps due to post milling wood movement during the acclimation period. I'll fill those before sanding.
So lot's of debate about finish. And to weigh my options I'll ask for recommendations. This is a bathroom and I am looking for a low gloss finished result. Epoxy? Water Based Poly? I'm open to suggestions.
Thanks
Tom
PS- I'll post pictures when done. This floor might look really cool!
Re: Bathroom Fooring Update and Finish Question
Chuck in ND
>First I'd like to say that filling the gaps is a waste of time, as I'm sure you know, wood floors move. As far as the finish goes, I would use a oil base poly, it resists moisture well. The sheen is up to you, but, the higher the gloss the more durable, I would atleast go semi-gloss and stay away from a flat or satin finish.
Traffic *LINK*
JohnM in Mid Mich
>We had new hickory floors installed throughout the first floor about 6 years ago, and the installer used a product called "Traffic", a water based polyurethane that he claimed was the most durable he knew of. It is holding up flawlessly even in the kitchen and with 3 big dogs. I was skeptical about water based, but am a believer now. We wanted the warming color provided by oil based poly, however, so he actually used an oil based sealer first, then the Traffic to finish. I found the link below when I just googled.
Traffic Waterbased Foor Finish
>Behr waterborne clear one-part epoxy. It's marketed as a garage floor paint, but works well on wood in my experience. I also used it on a travertine type stone tile on a bathroom floor. It's good stuff.
Clint
Re: Traffic
>Thanks for the link. I have a neighbor who is a painter for U of Illinois and he was mentioning a "$100 per gallon" waterborn finish they use on the basketball court. I have a feeling this is the same stuff.
Varathane Diamond Floor Finish
Lee Schierer - McKean, PA
>I would recommend the varathane diamond floor finish. It is water based poly designed for floors. I used it on a bathroom vanity and it has held up well for 2 years now. It comes in a variety of sheens. Lowes carries it locally here in gallons.
Lee
Re: Traffic
Fred Davis
>If you use the "Traffic waterborne finish". I would suggest following the manufacturer's directions and use the Water borne sealer specifically made for it .
I can't imagine a water borne finish over a oil base sealer, but who knows.
FredD
