Made two shoulder planes
Steve Kreitler
>Promised my SIL a shoulder plane for Christmas, and finally got around to it. Since I had two blades, and don't like to just make one of anything, I made two of them at the same time (yep- one for me, too :).
The design is from the Aug/Sept '08 Woodcraft, body is white oak (from a solid frame door I salvaged a few years ago- parts of it went into my workbench, too), the sole is purpleheart (from a piece my MIL gave me many years ago). The blades are cut down flat Unitool Chisel blades that I got at garage sale last year for a quarter each (lots of patience with the dremel, there- kind of a Zen thing). Width is 5/8".
These are the first planes I have made, and it was really enjoyable. I'm sure I'll find lots of uses for mine, since I like to make small items.
My technique in making them was different from the author's- he used the tablesaw to cut wide, shallow rabbets for the sides. I happen to know the the fence on my table saw is a couple of thousandths out of square, and I didn't like the chance of my thin kerf blade flexing while cutting these rabbets, so I used the router table instead.
I ripped the piece for bodies to the correct width, glued on the sole, then made the cuts for the mouth openings. I then ripped some long strips from scrap, and glued the bodies between the strips, aligning the pieces carefully. Then it was through the planer to flatten and bring it all to the desired width. Leaving the planer setting undisturbed, I used a 3/4" straight bit on the router table to cut the rabbet on one side at a time (setting the depth of cut so that the side would end up slightly proud of the body). Glued on one side, and ran it through the planer, then did the other side.
Using the scrap strips made it very easy to plane my workpieces to width, and making them long prevented any worries about snipe in the plane bodies.
I used my scroll saw to cut the final shape and also to cut out the mouth opening.
