drill presses
drill presses
drill presses
PJ
>I want to get my husband a drill press for his birthday. I have done some research, but am still in a quandry. It needs to be a qualilty free standing machine. Any help would be appreciated!
Re: drill presses
Re: drill presses *LINK*
Dave Paine
>It would help others to advise suggestions if you could provide some indication as to how this will be used.
By "free standing" do you mean a floor mounted/standing model? Drill Presses come in bench mounted and floor mounted.
The models differ by "reach" the distance from the centre of the drill chuck to the outside of the post. This defines how deep a hole can be drilled.
Is the machine to be used for drilling only, or also for morticing, sanding? One model in the attached link has an oscillating head which is desirable for sanding.
The machines talk about different speeds. If the machine is being used for woodworking, it is not likely to need to change speed often.
On my drill press, I have rarely changed the speed.
I am considering replacing my bench mounted radial drill press with a 20 in fixed head from Grizzly. I just need to figure out how to create the space for the floor standing unit.
The attached link is to one site, Grizzly Industrial. If they are driving distance you could give your husband a gift certificate and have him drive over to select the machine.
This site should give you some ideas on model differences.
http://www.grizzlyindustrial.com/products/category.aspx?key=380000
Re: drill presses
Re: drill presses
Chuck in ND
>The best bang for your buck is the Steel City 17" drill press.
Re: drill presses
Re: drill presses
Steve in Denver
>I'll second the Steel City DP, the $100 off has been extended through April.
Re: drill presses
Re: drill presses
>Quill depth may be important. This is the distance the drill bit can travel downwards. A drill press with a smaller quill depth will not be able to drill as deep a hole as another.
I have two Delta drill presses, one a bench model and one a floor model. They are nearly equivalent, but the bench model cannot drill a hole as deep as the other. This was a problem for me when I used the bench model to drill holes in blanks to turn pens on the lathe - it could not drill deep enough to go entirely through the blank so I had to drill the blanks in two stages. This was a pain in the neck.
The point is, depending on what the drill press will be used for, the quill depth may matter. All else being equal, I'd probably choose the one with the greater depth.
Re: drill presses
Re: drill presses
Charlie Self
>The new Delta models are superb. Designed specifically for woodworking, they also have more quill length than any other in a close price range, at least that I know of. The table is superb, as are the extra adjustments. The laser may or may not be handy. I don't normally use them, but others love 'em.
Re: drill presses
Re: drill presses
PJ
>Thank you for your insight. I now understand what quill length is! I see that there are several Delta drill presses. Other than I want it to be variable speed...are there specific models you can recommend?
Re: drill presses
Re: drill presses
PJ
>Is the Steel City a good press for the money or is it also an excellent drill press? This is not something I want to buy more than once. What makes it a quality drill press? And, where is the best place to buy one? It could be what I am looking for.
Re: drill presses
Re: drill presses
Chuck in ND
>The Steel City is the best in my opinion, it has a 6" quill travel, and a split head casting, usually only found on more expensive drill presses.
Re: drill presses
Re: drill presses
Jim Dillon
>PJ,
There are quite a few newer drill presses that have come out in the past year or so (Steel City, Powermatic, Delta), and even newer ones being announced (Jet XL). I have not kept up on the latest and greatest as I have been satisfied with my 10 year old Jet floor model. While I try to shop locally, sometimes that isn't possible, and the price difference is sometimes so great that online shopping makes financial sense to me. I purchased my Jet through Amazon (free shipping, no tax) and it arrived just fine; some assembly was required. FWIW, you might want to check out the reviews of the Delta, Powermatic, Grizzley, and Jet brands on the Amazon web site; I couldn't find a Steel City drill press listed, but a few other Steel City tools are. You can make an Amazon purchase through the WoodCentral link and WC gets a little financial support - but I wouldn't (sorry Ellis) let that be a major determining factor in your final decision. I really don't think you can go wrong with any of the brands mentioned in this thread. Hope this helps.
Jim
Re: drill presses
Re: drill presses
Charlie Self
>17-959L, 20-950 and 20-959LX are the newest Woodworkers' models. I know the 17 is a very good tool, and would guess the others are, too.
And someone recommended Steel City: their tools are excellent. In fact, I'm awaiting one of their granite topped hybrid tablesaws right now, for an article.
The Steel City 16" bandsaw uses the same trunnions used in the two larger saws, and it is more than adequate for them.
