Common tools defined
John Luke
>COMMON TOOLS DEFINED
DRILL PRESS: A tall upright machine useful for
suddenly snatching flat metal bar stock out of your hands so
that it smacks you in the chest and flings your beer across
the room, denting the freshly-painted vertical stabilizer
which you had carefully set in the corner where nothing
could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws
them somewhere under the workbench with the speed of light.
Also removes fingerprints and hard-earned calluses from
fingers in about the time it takes you to say, "Oh crap..."
SKILL SAW: A portable cutting tool used to make studs
too short.
PLIERS: Used to round off bolt heads. Sometimes used
in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used
to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on
the Ouija board principle. It transforms human energy into
a crooked, unpredictable motion, and the more you
attempt to influence its course, the more dismal your future
becomes.
VISE-GRIPS: Generally used after pliers to completely
round off bolt heads. If nothing else is available,
they can also be used to transfer intense welding heat to the
palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to
prolong the conduction of intense welding heat to the palm of
your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting
various flammable objects in your shop on fire. Also
handy for igniting the grease inside the wheel hub out of
which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly
used to launch wood projectiles for testing wall integrity.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times
harder than any known drill bit that snaps neatly off in bolt
holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used
by most shops to cut good aluminum sheet into smaller
pieces that more easily fit into the trash can after you cut
on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum
tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry
bar that inexplicably has an accurately machined screwdriver tip
on the end opposite the handle.
PHILLIPS SCREWDRIVER: Normally used to stab the
vacuum seals under lids or for opening old-style
paper-and-tin oil cans and splashing oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans.
Sometimes used to convert common slotted screws into
non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding
that clip or bracket you needed to remove in order to
replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the
hammer nowadays is used as a kind of divining rod to locate
the most expensive parts adjacent the object we are trying
to hit.
DAMMIT TOOL: Any handy tool that you grab and throw
across the garage while yelling 'DAMMIT!' at the top
of your lungs. It is also, most often, the next tool that
you will need
Re: Common tools defined
Sawman
>SOOO TRUE!!!
Hijack, Primitive Pete
Randy Johnson Connersville IN
>Yesterday I kept hearing something that sounded almost, but not quite, like a series of gunshots. Investigation showed that a neighbor was putting holes in the bottom of a 55 gallon drum using an old screwdriver for a chisel.
Somewhere in our conversation, Primitive Pete came up.
I'd guess that at least some of you who took shop class in the 40s, 50s, and 60s were exposed to Primitive Pete. He was born at the Walt Disney studios during WW II to teach GIs the proper (maybe I should say IMproper) use of tools. Pete was always using them in a fashion the Army considered incorrect.
However.....
Among my dad's "war stuff" was a companion book that went along with the movie I saw in 7th grade. Looking through it I was a little shocked to discover that, as an adult, I am a Primitive Pete. I occasionally use a screwdriver for a rough chisel job or to pry with. Very occasionally. I have been known to use an adjustable crescent in conjunction with a square shank screwdriver to get more leverage and have slipped a pipe over a wrench handle for the same reason more times than I can even begin to remember. I HAVE been able to refrain from using a file as a pry bar, but for the most part, if I had NEVER done any of the things forbidden by the creators of Primitive Pete some jobs would have been a lot harder if not impossible.
I�d bet Stanley worked with Disney to create Primitive Pete. They did it to sell more tools.
Bill White
>John, You now owe me a new lap top as I have sprayed coffee ALL OVER the keyboard. Too funny.
Bill
The original, and better, version
Rod Peterson -- Ormond Beach
The Right Tool for the Job by Peter Egan, “Road & Track”, April, 1996
Rod
Good catch Rod, and a reminder not to forget.....
Art Silva
>the "Attribution Rule". Mr. Egan's work has graced the walls of many shops, both auto and wood, for many years, and has been the cause of many belly laughs.
I actually got permission…
>…from Road & Track to post it on my website. Of course that was several years ago, and ownership of copyright was a little murkier then (at least to me). I might should contact Egan and get it from him, too.
Rod
Re: I actually got permission�
Lynn Baker in snowy Glacier, WA
>Rod,
Thanks for showing the list again. I actually saw it for the first time in R&T long ago. For me, the most apt and hilarious description is for the trouble light. I think that most of us, at some time, have used up every bulb in the house in an extremely short time trying to finish a job.
Thanks Again.
Lynn
