THE WOODRAT IS BACK!
Repaired Sanding belt on Performax (Tip)
>I have a couple of belts or rolls for my Performax that have the end torn off. The other day one lasted about a minute before the end tore off and the strip came loose. At About $7.50 each, I was bummed.
Today, I put it back on and hooked the torn end into the "start" clamp on the outboard end of the drum, wrapped the belt and found it to be exactly too short. The other end just barely reached the slot. I put some double stick tape on the drum, about three inches of it. The strip of tape was parallel to the END of the drum. Firmly pressed the roll onto the tape and then decided to put a strip on the other end too, because that end of the sandpaper was a little ratty from being torn. Took a lot less time to do than to explain, and it worked. I was careful to make light passes, but it worked fine. Probably would have been good to hook the good, untorn end into the start clamp and just use the tape on the end near the motor.
Just thought I would pass this along because I know others have torn these strips also.
