New TV program—Extreme Loggers
Rod Peterson -- Ormond Beach
>Discovery Channel started this one last night. I've watched the first of three (so far) episodes my DVR caught. It was about mule logging and was very interesting. A little less dramatic for a reality show than Ax Men was last year, but still very informative. I'm sure it'll be repeated.
The mill they took their loads to was neat to see, although all that was shown was the unloading of the logs and the grading. If you read Bill Tindall's seven part series, Where Hardwood Lumber Comes From, published last year in the WoodCentral Articles section, you'll be able to appreciate the process of grading and selling in particular that he described from seeing this episode.
The narration said they were logging in southeastern Tennessee, but the mill is located smack dab in the middle of the state. Hard to imagine they'd need to drive that far. Maybe Bill will have some insights.
Rod
Re: New TV program—Extreme Loggers
Re: New TV program�Extreme Loggers
Thomas S Stockton
>I can kinda answer the part about why they trucked the logs so far. A couple of years ago we had part of our property logged and depending on species and size that determined where the logs were sent, the closet mill is about 20 miles away some went there and some went about 45 miles away to the next closet mill. The small cedar logs went 145 miles away to Oroville CA because that was the mill that was set up to cut them They also paid us more for the small cedars than the large ones because of the hauling costs.
Right now the mills aren't buying logs around here because of the housing market crashing and also because of all the fires in northern California there is a lot of salvage logging going on so the timber companies are trying to get as many trees cut on their own property before they have no value from bugs and rot and getting a timber harvest plan for salvage logging is a pretty short process compared to a normal THP.
Tom
Tom Dunlap
>The crews that were featured on 'Ax Men' are all being inspected by state and federal OSHA for all of the extremely unsafe work practices. There will be some multi-thousand dollar fines laid on them when things are finished.
As I watched the one and only AM programs I was so disgusted with the poor safety that I turned off the show. During the twenty minutes that it was on there were about ten extreme safety violations that could have cost a life in a fraction of a second. But...that's what happens when a producer gets them jacked up for a bit of 'reality'. Not that logging isn't unsafe on its own of course.
This new series has gotten some good vibe, like what was said here. Much more a reality!
Jammer logging?
>The one guy using the yoder like a fly rod struck me as potentially dangerous—particularly when he did it in a heavy fog.
Rod
something amiss
Bill Tindall, E.TN
>Unless the logs were something special- veneer, whiskey barrel stock, etc.- they aren't making any money hauling logs 100 miles of more. 50 mile trips are fairly common in these parts. But then if someone is logging with mules they aren't intending to make any money, its a life style. Are they using a cross cut saw for felling?
Re: something amiss
Yeah, Stihl.
It wasn't entirely clear to me, but I got the impression that the mule part was for low impact on the "roads." Power or manual sawing wouldn't make much difference, I wouldn't think, except for the carbon footprint thing.
Rod
Re: yoder??
Claudia Hayward
>I'm familiar with a lot of logging terms but never heard of a yoder. What is it?
Mechanized logging *LINK*
Tom Dunlap
>Take a look at the heavy machinery used, especially in the west, to move logs to the yard.
Yarding
Typo: yarder not yoder
Tom Dunlap
Re: yoder??
brent w.
>actually, some of the hydraulic loaders have a set of winches for short (< 700 ft.) yarding. we refer to them as a "yoder" yarder+loader = yoder
Re: New TV program&mdash;Extreme Loggers
Typo, maybe, but more likely yoader not yoder
>I had to do some searching on this, because I was sure of what I heard (and a yoader looks nothing like a yarder, although it can do the same job).
What I found out was a “yoader” (or yoder—I've seen it spelled both ways) is a combination of a loader (the base mechanism) and a yarder (with an attachment at the end of the boom for handling the skyline), hence the name, and probably a hint at the correct spelling.
Rod
Yoader it is...you're right!
Tom Dunlap
