Bureau drawer slides
Brian
>My daughter has a five drawer bureau with 16" Blum euro glides. The drawers are 55" wide and there is no center case support. These slides have failed and are (IMHO) totally inappropriate for the bureau. The case side slides are bent and generally there is alot of lateral slop and some of the slides are bent. BTW - these are the light weight blum slides.
Any thoughts on how to upgrade these? I have limited experience with drawer slides.
Thanks.
Re: Bureau drawer slides
Ed Mulligan, Cape Cod
>Brian,
The slides you describe are inexpensive but they are rated for 100 pounds so they should be adequate to the task, but obviously they are not.
The sideways slop you mention might be a clue to the problem. The drawer width, at 55" is very wide so any sideways slop in the slides or the drawer width tends to get exaggerated. The side clearance should be 1/2" per side. If it's more, the drawer will tend to bind if it's not operated cautiously. Shimming could help.
Is the dresser structurally sound? Sides not bowed, case doesn't wrack etc.
You can replace with more expensive slides, but if there is an underlying problem with the construction your fix might be temporary.
Ed
Brian
>Greetings from Worcester, MA and thanks. I'll try shims and new Blums. Also, a center support might alleviate some of the stress. Since the bureau was designed with these drawer bottom slides, I don't wish to mess with the layout.
Glenn Madsen near San Francisco
>While you're in there, replacing the slides, you may consider beefing up the infrastructure a bit with some additional wood. Plywood, poplar or white pine might sturdy it up some.
I know that my wife tends to overstuff dressers, etc., and so virtually everything has been 'upgraded' over time. New materials are appropriately sized. Typical commercial doesn't do it in our home.
