Closet door frames
Closet door frames
Closet door frames
Nathan
>I live in a part of the world where masonry is the material of choice not only for weight-bearing walls, but for partition walls as well. All of the masonry work in our house is done and now I'm very slowly doing the interior carpentry work. The latest project is to frame in the openings of two closets and install louvered doors in the frames.
I cheated and purchased the louvered doors at a box store. But the frames I am making in the shop from air dried 8/4 pine slabs. I'm using a circular saw with a guide to cut off 3/4+" thick strips from the slab and then edge-gluing the strips together to get the boards.
At this point, I have all of the vertical members done (four total). Each member consists of two boards glued together at a right angle. Once I have all four, I will glue them to the masonry wall using neoprene-based construction glue (thick stuff that comes in a tube, like caulking - holds very well).
This photo shows some of the boards being readied for glue-up. You can see the dowels I wrote about earlier which I am using to line up the boards for glue-up. The thin board in the middle is the pattern board which I'm using to line up the holes - as advised here on Woodcentral - it works well, as long as I don't have the board backwards! The first glue-up is finished and you can see the result on the far right.
Before I install them I will paint them white.
Re: Closet door frames
Glue-up
Nathan
>Here's a photo of the second glue-up (in progress).
I know this is probably really basic stuff to you guys, nothing to crow about, but for me it's a major project.
I'm looking forward to getting the doors installed. My wife still doesn't believe it's going to get done. I can't blame her!
Off to scrape off the glue.
Don Orr
>Looks really good Nathan ! I hope your wife is pleasantly surprised when you are done. That's not a simple project in my book. Good luck.
