Drill press to sharpen chisels and plane irons
Nathan
>I'm wondering if anyone has converted their drill press into a disc grinder for sharpening chisels and plane irons. My idea is to run the drill at low RPMS (200). Basically I would like to take a short piece of 3/4" steel rod with relatively big flange and a thread on the end of it and chuck it up in the drill press. Then I would have some discs turned for various grits of PSA wet/dry sandpaper and attach those (one at a time) to the rod, using a nut to tighten them up against the flange. To hold the tool at the correct angle, I'd use a specially-made jig clamped to the drill press table. To sharpen a chisel, I'd press it onto the jig and gently push it upward until it makes contact with the sandpaper on the bottom side of the spinning disc. (Something like the Work Sharp except I would have to work blind.)
If anyone has a setup similar to this, I'd like to hear how it works for you, what you would do differently etc.
Re: Drill press to sharpen chisels and plane irons
Unnecessarily complicated
Bill Tindall, E.TN
>1. Buy a grinder and an appropriate (soft bond 80 or 100 grit) tool grinder wheel for it.
2. Use your creative skills to make a large flat tool rest whose angle can be adjusted(or buy the Wolverine from Oneway).
3.Practice making a hollow grind on chisels and plane irons. Use a very light touch and whisk away tiny amounts of metal at each pass across the wheel. If the wheel is sharp ( as a result of the soft bond and dressing as needed) burning the edge even at 3600 rpm is not a problem.
4. Follow up with a few strokes on a fine fixed diamond plate.
5. Hone, if you wish, on something finer-water stone, sand paper, etc.
Because of the hollow grind steps 4&5 take but seconds. Steps 4&5 can be repeated several times before it is necessary to regrind.
In my mind the whole concept of sharpening on abrasive disks is flawed. To keep from heating the tool the grits must be fresh and sharp which is only the case when they are being constantly renewed. They are renewed on a soft wheel and they are not on an abrasive disk.
A moment of Zen......
>I tend to agree with Bill. There seems to be at least two schools of thought on sharpening. Those who want things sharp and those who want to sharpen things. Or perhaps those who would like to do woodworking with sharp tools and those who want to sharpen tools.
Clearly I missed the gene that seems to get Zen like pleasure out of sharpening things. Threads like this make me wonder what I have missed. If I had water stones and all those other tools and devices I read about on sharpening threads would I enjoy my shop more or makes better stuff?
In my shop it is sometimes hard to tell a chisel from a screw driver. (Nonsense, Chisels have handles you hit with a mallet or a hunk of wood if the mallet has run off yet again and screwdrivers leave that little X in the wood if you hit them with a hammer.)
On the few occasions I have ventured over to the Quiet Side I have seen much discussion about sharpening things, but I assume they would think it a heresy to use a power tool to sharpen a hand tool.
OTOH, I do sharpen my planer knives and jointer knives. I do what Bill said. I have a micro adjustable tool rest on a grinder and I set it up by eye and slide the knives by it until it stops cutting. I have two sets of knives and I do all of them at the same time so they are "dynamically balanced". I blacken the edges with a magic marker and when all of it is gone on all four knives, I quit and I hone them by hand with a small cheap diamond hone. The reason I do all of them at once is so they are interchangeable. If I nick a set, I swap the blades around to avoid having to grind the entire nick away. At least until I get too many nicks. Maybe they would work better if I had them professionally done, but I don't know how. They work nearly perfectly except in very difficult stock. Takes about an hour. About the same amount of time it would take me to package them and mail them to a sharpening service or to drive them to one. So it does not cost me time, but it saves me money. The same gadget does a great job on chisels and planes.
Re: Unnecessarily complicated
Nathan
>Thanks, Bill. I do have a small Chinese crap grinder but it shakes like crazy and takes really thin grinding wheels so I will buy a real grinder. Over here on this side of the pond I can get a two-speed with the lower speed being 1400 RPM.
For steps 4&5 I will have to make a jig to hold the tool at the correct angle (don't trust myself to do it by hand) but that shouldn't be too complicated.
steps 4&5
Bill Tindall, E.TN
>Had you told me I could hone free hand before discovering hollow grinding I would have dismissed the idea as impossible. But indeed I can, and do. The secret is the hollow grind left by the wheel.
The hollow grind does two things. First, each honing step only takes 5-10 strokes because only a tiny bit of metal needs to be removed at the edge. It is vastly easier to maintain proper orientation for 5 strokes than 50, at least with my attention span.
Second, if the honing surface is smooth and lubricate with oil or water, the hollow sucks onto the planar abrasive surface and provides secure orientation. I find it very easy to establish the proper orientation of the tool before pulling it across the abrasive surface. I rock the tool a bit and feel for the bevel to be sucked onto the surface. Skewing the tool at an angle while pulling it toward you establishes even more bevel in contact with the abrasive.
Practice with something that is thick and hence has a wide bevel. Stanley plane irons are the hardest to do because they are thin and have a narrow bevel. A wide chisel is much easier.
