Re: Help with Multi Piece Inlay
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I have not done any of this is a long time, but here are a few things that I did.
First, I didn't like the fine tip of the x-acto blades. They tended to try to follow the grain when the cut-line comes close to lining up with the grain. I liked to sharpen my own blades. They are a little thicker, and while narrow front to back, I like to have a little turn back at the tip, which helps it track better when making the first scoring pass. The second pass usually stays in the groove of the first pass pretty good. It might split down the grain too, if I tried going all the way through on the first pass.
Rather than trying to cut individual parts, I liked to work from one side to the other. If you let the parts overlap, you can cut through the top piece, which will guide the blade as it cuts the next part under it.
You can lay one cut part over the next, and use it to guide the blade by using the dots to hold it, working between dots, then putting on new dots where the cut is already made, while cutting under the first set of dots, but you have to be careful to not let it squirm where the tape bridges between the two levels.
There are a number of two sided tapes. Some are too sticky to use. For this, you want one that has a thin vinyl core, but doesn't stick so hard that the parts break when you try to take them apart.
As you get mating parts, I like to use drafting dots to hold the parts together. They are made to peal without leaving residue, and or tearing things up also.
