Windows Activation
Windows Activation
Windows Activation
peter stahl
>I turned on my PC today and got a screen I never got before. It asks if i want to Activate my Windows software. PC is my daughters old computer and she has no idea where the disk is. How can I find out what the numbers are for the registration? I've been using this PC for years and this is the first time this popped up. Just used it yesterday and it didn't do this. Is this something Microsoft just started. Any help is appreciated.
thanks, Pete
Re: Windows Activation
Bill Howatt
>Normally for the activation you don't need the CD or anything. If you are connected to the internet you can click on the Yes or Activate button and it should do it within a couple of seconds. If you aren't then there is an 800 number to call Microsoft. Be sure you have a pen and paper or the machine to enter the number in because they will apparently give you a big number to enter.
Did you add or change any hardware on the system? That is what normally triggers the need to re-activate. I did have it happen once, not with Windows but with a MS-Office program, when I had a bank of memory go bad. Thought it was strange at the time but c'est la vie.
Bill
peter stahl
>Bill,
Haven't put anything new on the PC in a long time. I may have update when it was shutting down as I clicked shutdown then turn the monitor off.
Dave Paine
>As another reply stated, you should not need the registration key. If Windows is working, you can see this by going to Start - Control Panel which should open at the "General" tab. In the middle of the tab is the "Registered to" portion, which should show the version, e.g., Windows XP for my system, then below is the registration key.
You may need to call the 1-800 number. This will display a series of numbers/letters which is the Activation key. This is normally "automatic". It represents codes for the CPU, Video card, RAM, hard drives, etc.
I recently had to install new hardware, including the hard drive, and had to re-activate by calling the 1-800 number. Did not take long. Expect to hear an Indian accent.
As for what caused this, it is not easy to diagnose remotely. The activation data is saved in a special file on the hard drive. If this became corrupt or unreadable, it would trigger the need to re-activate.
Hard drives do have parts of the drive go bad. It is normal. Most of the time the operating system handles and by-passes the bad sectors. Every now and again the bad sectors can be an important part of a file.
I once had a hard drive with a bad sector in the data representing the folder "C:\Windows". As you can imagine if the folder cannot be read, then none of the files or sub-directories can be read.
I happened to own a special utility which allowed me to set the sector as bad and re-create the "C:\Windows" data. Saved me a lot of time in re-installing.
Chuck W
>Peter,
google "magic jellybean"
Peter Stahl
>Well I had to call Microsoft and after going through 3 people I finally got it going again. Was hoping for a easy solution but it only took about 25 minutes, wasn't as bad as I thought it would be Thanks everyone for your help.
Peter Stahl
>Chuck, Thanks for the Jelly Bean link. Wouldn't help because I couldn't get that far but I did use it after calling and getting reactivated. Showed the new Key Number.
Re: Windows Activation_How to backup *LINK*
Dave Paine
>I was doing some research on another topic and found a very useful site about XP tuneups. Link is attached.
This site explained that the Activation data is saved in e.g., C:\Windows\System folder in a file called "wpa.dbl"
So if you save this file in a safe place, other than the hard drive and happen to corrupt the file, or need to re-install windows, you can copy this back to the same folder and are back in business.
This will only work in Windows was originally activated, the PC equipment did not change, etc. This will not work with a "hacked" XP installation, or using someone else's XP license key.
http://www.xptuneup.com/tip0025.htm
Re: Windows Activation *LINK*
Will Abbott
>I use this software on all my computers. Run the scan, and print the results for future reference.
Belarc Advisor
peter stahl
>The Key# that Belarc gave is a Manufactures Key#, not the one on the label. Guess I'll have to copy this down in case the label gets worn off. Thanks for the info, forgot about Belarc. Used it years ago and it has come in handy.
