Purchased peg weirdness...or is it me?
Ken Platt (granby, CT)
>Folks -
Normally I'd turn my own pegs. But time is in short supply, and this is just for a quick home project. So I dropped into Woodcraft and picked up a package of large shaker pegs. I assumed they'd mount with a tenon in a standard size hole.
Tonight I pulled out the pegs and had a look so I could drill the holes for them. (Who says I don't know how to celebrate New Year's, eh?) First thing I notice, the tenons are tapered. And not just a little, so the outside will fit tightly, but tapered a lot. I pull out my digital calipers, and the bottom of the tenon is 0.69 inches, the top 0.79 inches.
I'm mystified. First, why would the tenon be so tapered? Do they expect people to drill a tapered hole somehow? Second, why the weird dimensions? I'd assume anyone buying these pegs would have a 3/4 inch bit, but that's too loose at the bottom, and not big enough at the top. I realize that 13/16ths or 25/32nd bits exist, but it's certainly not sizes that most would have sitting around.
Am I missing something? How are they expecting these pegs to be mounted? I found I can use the dremel to enlarge and taper the hole a bit. It takes about a minute per hole, and I only have ten holes. But I can't help thinking that I must be missing some simple answer....
Anyone? Thanks -
Ken
