>I bought some of these "L" shaped wire things, screws on one end that go into a board and poke through the wall. They give you a floating shelf. I got them at Woodcraft a few years ago, and were made by Magic Shelf. Now I need more and can't find them, anyone have some or a suggestion? I did extensive Google searching and no luck.
If you have the opportunity to replace them with something else, it is simple to make hidden brackets with interlocking pieces of wood cut at 45 degree angles lengthwise.
>You don't mean these, do you? I use them to mount small shelves on pegboard but I can't imagine using them in a wall unless the shelf was small and would not be used for much weight.
I've mounted shelves with steel rods before: drill holes into both the wall studs and the shelf.
>I did look at those sites, and none have them. It is interesting that they use the same name too.
(Photo attached)It screws into the back of the shelf, you poke holes through the drywall and insert the wires. Claim to hold 8 lbs/wire. Since I am putting turnings on them, I won't be anywhere near the weight limit.
>I'll bet you could make those by bending some steel rod, glue into a hole instead of threading. For an inexpensive material source, farm stores carry very heavy gauge steel wire that would work.
