making compound picture frames?
Dave in St Paul, MN
>I remember the old, maybe still current, ShopSmith info-mercials where they would make the picture frames that had 45 deg corners with a compound cut. The compound cut allowed the inside to be "in" further, with the outside perimeter "out".
I have a Rigid compound slider miter saw that tilts and zigs and zags in every way imaginable, and probably even some I haven't discovered yet. I set the table at a 45 degree angle for the corner, then tilted the blade a few degrees to create the shadowbox effect. What I found was that when I tilted the blade and made my cut, the 45 corner was no longer 45.
Any book recommendations, helpful websites, or experienced picture frame makers with some pointers for a frame-building novice? 8-) I've done trim carpentry and so use my CSMS efficiently, just not for pic frames, YET.
