Nontraditional cheese board
Clay Foster
>The wood is QS sycamore. About 17" long.The cheese ball is goat cheese/parmigiano with garlic, pecans, cilantro, and toasted almond grapeseed oil. It will be a gift to the hostess at a party New Year's Day.
Clay Foster
Outstanding!
doug f, san clemente, ca
>Clay - I'm fascinated by your cheese board. Does it stay in place when the cheese is cut or does the "board" lift off? If it stays in place, how did you determine the placement and how is the board fastened to the stone? Your cheese "knife" is a great bit of design whimsy also.
The whole piece is extremely well designed and executed.
Congratulations on an exception piece of work!!
Doug
Re: Outstanding!
Clay Foster
>Thanks, Doug. The wood is attached to the stone with a couple of dowels glued into the wood and epoxied into the stone. Sandstone is easy to drill with a masonry bit.
Lucky hostess!
mdclor
Re: Nontraditional cheese board
Jennifer@Indy.USA
>Um, Clay, My name is Jennifer and I'm a cheeseaholic. I was trying to turn over a new leaf for 2009 and limit my cheese intake but thanks to you I may need to whip up one of these cheese balls.
I love this rendition of your Ripple Piece as a funtional party aid!
Happy New Year!
charlie belden
>With each of the pieces I see you posting here I keep wondering a) when you have time to sleep and b) how, when you do sleep, do you get any restful sleep with all those ideas flying around - your mind coming up with so many ideas with so many variations of just a single idea.
What's fascinating is your ability to think non-linearly, making connections acrossed disciplines - geometry, turning, carving, finishing, masonry, furniture making - and combining them - in a coherent and quite creative and unique way.
Have you considered adding electro-forming to your menu of choices. Unlike electro-plating, which only puts down a tiny amount of metal, electro-forming actually deposits enough metal to have some structural strength - AND - lends itself to patination - and a range of colors and shades. Make ANY surface conductive and you can electro-form on it. You can follow the surface and merely add enough copper (or whatever you want to plate with) to provide a metalic surface - which can then be patinated - or - kick up the current and plate for longer periods and "grow" nodular, organic looking surfaces over the underlying form that's been made conductive (there are conductive paints - the electronics folks use them all the time)
Assuming there are no undercuts on the base form, you can remove the electro-formed copper - and - enamel some or all of it - adding glass to the possibilities.
A plastic 5 gallon bucket, some pieces of copper for the anode, some copper sulfate and some dilute sulfuric acid plut a small battery charger and you can electro-form. Throw in some gelatin powder to increase the "throwing power" and you're off to the races.
I know - more possibilities - as if you need any more. I mean, who else would have thought of combining wood, stone - and cheese - and a hemisphere of cheese at that?!
Clay Foster
>Thanks for the kind words, Charlie, and for the info. When I get through with rocks ans sticks, I'll check it out.
