Need to learn how to Spray
Bart Goldberg
Bart Goldberg
>Hi All,
Santa left a new spray gun under the tree for me this x-mas (yes, I know, I'm Jewish - long story). Wifey got me a gravity feed gun from Homestead Finishing that is for use with my compressor. It came as a kit with a case - I guess I wasn't to naughty this past year :).
Problem is that I have never sprayed anything in my life, except paint with one of them Wagner spray guns, and that was many years ago.
I'm looking for a good book/video on how to spay, how to set up, use and clean the gun. Also would be interested in plans for a knock down spray booth.
One last request: what is a good finishing product(s) to start with? I do a large range of projects from gift boxes made from exotic materials (purpleheart, ebony, etc.) as well as larger projects like desks and bookcases from local domestic hardwoods (Oak, Cherry, Walnut, etc.)
Any help is appreciated.
Regards
Bart
P.S. remove the "2" to send me mail
Re: Need to learn how to Spray
steps to learning
Bill Tindall, E.TN
>Spraying enables finishes to be applied that can't be done by traditional means and it is faster by far than traditional means for the traditional finishes.
1. look into the 3M PPS system. I will report on it in a post next week.
Here is what you need to learn: How to thin various finishes as necessary, how to adjust the gun for optimum coverage, how to "triggger" the unit to deliver finish where you want it, how to lay down an overlapping pattern to achieve uniform coverage, how to determine a strategy for applying finish to minimize over spray on places already done.
2. Load the gun up with some water (water doesn't spray very well but that doesn't matter at this stage) and spray a piece of cardboard or the side of the car or anything. (you could add food color or tempra paint to see how you are doing if the target is cardboard) Practice starting the spray off the piece and then fanning the gun across what you want to finish and then releasing the trigger after you have passed by that to be finished. Never start or stop the spray on target until you gain experience as to when you can get by doing it.
3. Diddle with the various adjustments, usually how wide is the fan and how much stuff comes out, and feed pressure to see how they work.
4 Practice spraying in a 1/2 overlap pattern. That is, each pass overlaps the last pass by 1/2.
What to use..........I find thinned oil based paint or solvent based Kilz the easiest to spray because you can see where it it going and how much. But it is also the easiest to get runs. Also it can be hard to clean out of a gun if clear lacquer is to follow.
Nitrocellulose lacquer (available at Sherwin William and many other places) is formulated to be sprayed so it is the most run-resistant stuff you can spray. The challenge is to get good lighting so you know how much is going on and where. To spray this material you will need lacquer thinner to clean up the gun, and a can of retarder so slow drying when it is hot.
Always spray a test piece to be sure the adjustments are appropriate for the material at being used.
Have at it and ask questions as problems arise.
Fred Davis
>In addition to Bill's comments,
It is very important to learn to straighten your arm and lock your wrist and maintain the same distance thru each stroke or pass of the spray gun.
Not doing this will give you varying results thru each pass if you swing the gun in a arc ,which covers the middle of the swing (closer to the surface being sprayed) with thicker coverage, then thinner coverage on the beginning and ending of each swing.
For my own spraying needs , nothing bur Lacquer or Shellac and the thinners ever go thru my hose and gun, simplifies cleaning and eliminates possible contamination of one finish like paint to another clear finish like Lacquer or Shellac.
Your spray gun instruction book with give you a good start on using and cleaning that particular gun.
Then like Bill said , practice.
FredD
Re: Need to learn how to Spray *LINK*
mdclor
>Bart,
Homesteadfinishing.com and targetcoatings.com both have good forums that are very helpful, although Jeff Jewitt's site is off line until after the 1st of the year. I haven't started spraying yet, but will use water based products when I do due to the relative ease of use...you don't need explosion proof light fixtures and exhaust fan, etc.
Regarding your spray gun, talk with Jeff J about the N/N (needle/nozzle) because that will, in part, determine what you can spray, i.e. the viscosity you can push through the gun. This is also partly determined by the size of your compressor, but I am certain that Jeff J would have sized everything appropriately.
Finally, Jeff J did an article in FFW about constructing a simple spray booth at the below link.
HTH,
Merle
Simple spray booth
When you learn, let me know
GolfSteve in Calgary
>I bought a spray gun about a year ago. I've only sprayed three or four projects and I'm still on the steep part of the learning curve.
The 3M PPS system is great.
I've spent the past week spraying a small table-top and have rediscovered every mistake I've made on the past projects. While I love spraying dyes, they are also my bane because any mistakes are very difficult to fix...eg. sanding through a barrier coat and into a dye coat is frustrating.
Here's what I've learned:
Thin coats are good. Resist going over the piece with one more time to get that "wet" look; that's when you'll get runs or screw up.
Lighting is important.
Temperature is important. Where I live warmer is better.
Viscosity is important. Get a viscosity cup and match your finish viscosity to the needle size your gun has or vice-versa.
Clean room cleanliness would be a god-send, but cleanliness is not as important as I thought it would be for spraying. The finishes dry so fast that dust does not have much chance to settle into the wet finish.
Straining your finish before spraying is important.
Sanding and rubbing out the finish after spraying is a lot of work. I've only sprayed gloss finishes; some day I need to buy some semi-gloss and try spraying that.
Reading about spraying does not teach you very much. I found copies of one of Jeff Jewitt's and Michael Dresdner's videos at the library and they helped a little bit.
Once you get a taste of spraying dyes you'll be applying dyes to every project. I love the Transtint dyes.
Target's water based Oxford lacquer is pretty good, is easy to spray, and the finish has lasted very well with my 2 year old using the coffee table as a playground. I didn't like their water based shellac - too hard to sand and it remains water soluble after drying.
I have trouble spraying alcohol based shellac and I don't know why. I get lots of orange peel if I spray a wet coat. The shellac coat is also very soft for a long time. I'm using fresh shellac flakes and Lee Valley's denatured alcohol.
With the Target water based lacquer I don't get orange peel unless I screw up (sigh...)
Every time I've sprayed the water based lacquer, the final coat ends up getting a few gobs of gelatinous finish in it (it happened to me tonight). Seems like some stuff starts to gell in the gun after about five or six hours; just about the time I'm putting the final coat on. The lumps sand out OK, but then I have to sand the entire top down and then polish it up to my desired polish.
I thought I would try out spraying to see if it would reduce the time required for the finishing phase of a project. So far it's not saving me any time compared to wipe on poly, and I dread the thought of trying to spray a complicated project, but I'm perservering because I think spraying offers the potential for saving time, and offers much greater variety of high quality finishes.
I wish I could take a wood finish spraying course but I can't find one offered locally. There is an extensive couse offered at the local college for auto-finishing that I'm considering, but so much of the course is about pulling out dents and sanding bondo that I'm not sure it's worth it.
Always wear your respirator.
Nikos Annitsakis
>Bart,
take a look at the DVD pointed to by the link. The section "Spray Basics", which was released as a VHS tape by Fine Woodworking several years ago, contains answers to most of your questions. It is interesting to see how a very knowledgable person manages to teach all the basics in a span of about 20 minutes.
Nikos
http://www.michaeldresdner.com/booksvideos5.htm
Steve Worcester
>Probably the most important is knowing how to adjust the gun, try this link
http://www.southernpolyurethanes.com/homepage.htm
Get some plywood and whatever finish you are using (and a good, comfortable mask) and start playing.
Herb Yost
>About 5 years ago I brought an HVLP spraying set, figuring it would be a piece of cake to use. I tried everything....read the books, following the instructions, practiced, etc....but was just not confident enough to commit to spraying a finished piece. Was too afraid of ruining it. So the equipment sat in the cabinet for all that time, till this past summer when I took a Teri Masachi class.
That's my advice: ya just can't beat a class with hands-on experience. It was a great confidence booster. Have you tried Googling "spray finishing classes?" Maybe there aren't any in your area, but perhaps you can combine a class with a family vacation.
Steve Jenkins, McKinney, TX.
>Where are you located. There may very well be one of us not too far away that would give you some hands on lessons.
Steve.
