I've just completing a decorative keepsake box that uses Purpleheart for the legs and top. I put a first coat of Waterlox Sealer on and found it to come out blotchy, like the purpleheart was bleeding Waterlox from its pores. It dried ok, but I had to basically sand off the finish to get it to even out again. Any idea why this is happening?
>Sorry, couldn't resist. As Clint said - lacquer. I haven't tried it, but a friend used one of the water based acrylics on a piece that had a purpleheart inlay and it looked very nice. Just don't expect the purple to last.
>Porous woods like red oak (and presumably purpleheart) often bleed excess finish out of the pores. You need to remove the dried splotches with fine steel wool before applying the next coat. It doesn't take too many coats to start building the finish without this bleedout, but it is a nuisance. A preliminary coat or two of thinned shellac will help prevent a lot of this bleeding.
Lacquer, like Clint suggests, is a good choice for purpleheart and other fugitive-colored woods because it dries uneventfully and tends to preserve the bright color of the wood for a longer time, especially if you keep the piece out of bright light. If you don't care for or want the characteristics of the lacquer film, oil finishes and varnishes are fine, although they can pose problems of their own as you have found out.
