Work Sharp - Anyone ever used one?
slozuke
>I'm looking for something to sharpen my blades with and am thinking of the Work Sharp 3000. I've seen reviews using it to sharpen chisels and plane blades (mostly flat stuff) and they all sound favorable. However, I can't seem to find any reviews addressing sharpening lathe tools. Has anyone out there used one of these for sharpening curved surfaces? I'd appreciate any feedback.
Thanks!
Re: Work Sharp - Anyone ever used one?
Fred Davis
>If your primary sharpening task is lathe tools , take a look at the jig OneWay Lathe sells , best there is.
FredD
Robert R Clough - Thorncraft
>I have a Work Sharp. It does as advertised and well. It is easy to use. I use it only for flat work not being a turner. However, I understand from the instructions that lathe tools can be sharpened easily using the slotted wheel.
Charlie Self
>Same here. It does a fine, quick job on flat tools. I don't turn, so I can't comment on the turning tool uses, but the manual says it does.
Bill Spievak
>If you are interested in sharpening chisels and plane irons that fit in the slot it is a great piece of equipment. It is fast and accurate. I touch up the results with a very fine diamond stone when I want a really sharp edge for paring, but otherwise I use the edge right out of the Work Sharp. I have a friend with a Jotool, I tried it and didn't like it so I haven't tried the slotted wheel technique. Until I got the Work Sharp I used sand paper on plate glass. I still do for wide blades.
Re: Work Sharp - Anyone ever used one? *LINK*
charlie belden
>Let me preface this by admitting - I'm a Tool Phreak. And when it comes to sharpening I've taken that to the extreme - Scary Sharp, india and arkansas stones, waterstones, those DMT diamond plates, a two wheel grinder with upraded stone wheels and Wolverine Jig plus accessories, the Tormek plus accessories, the JoolTool with extra Ninja Stars and abrassives to go with them - and - the WS3000.
Oh - BTW - being able to shave hairs from you forearm is not my criteria for determining sharp. That'd be semi-fairly sharp - sort of. But if you want to cut shavings - not scrape dust - you want SHARP - as in "Keep any and all parts of your body away from this edge".
As others have noted, the WS is the fastest and easiest of them all for bench chisels and plane irons - with square to the sides edges - assuming you want bevels that are 20, 25, 30 or 35 degrees. And, for those applications, it's as close to Idiot Proof as I've found - and I'm a very clever idiot. If there's a way to screw up - I'll find it!
The use of the slotted wheels and sharpening from underneath - well - there's a question or two that need answering first.
Are we talking about curved bevels like spindle, bowl and roughing gouges?
If so, do you use a jig - say like the wolverine jig - to curently sharpen them - OR - do you free hand them?
How good are your eyes - with glasses if you normally wear glasses?
The From Underneath Looking Through The Slotted Wheel method requires that you blacken the bevel you want to work on - with a Sharpi - or other black felt tipped pen. YOU then bring the blackened bevel up to the underside of the slotted wheel and look for disappearing black ink to see where you are making contact. THEN - staying on that bevel as you move the tool - well that's up to you. YOU are the "sharpening jig".
But if you've been turning much you're use to moving the tool and rotating it around two different axis - at the same time.
I don't know if WorkSharp has an online video showing the use of the slotted wheel, but JoolTool has videos that show the procedure. Go to Jooltool.com and scroll down to and then click on "Media"
WorkSharp 3000 Review
Yep, and I love it for lathe tools
Michael Dresdner
>I have a WorkSharp complete with the new large blade plate addition, and I adore the thing. It has completely supplanted every other sharpening means in my shop, which includes a grinder fitted with a Wolverine, water and oil stones, and sandpaper on glass.
The best, though, is how it works on lathe tools. Because you can actually see the edge being cut through the slotted wheel, you can grind any angle or configuration you want quickly and easily. Personally, if think WorkSharp is the best sharpening tool anyone has come up with.
If you want to ask anything more about it, feel free to contact me. You'll find my email address and phone number on my website (www.michaeldresdner.com)
