Thinned BLO - how long to dry?
Joe in a Cleveland suburb
>Hi,
I just applied thinned (with oderless mineral spirits) BLO to a walnut table top. I sanded it creating a slurry then wiped it off.
How long should I let this dry before I can wipe on some poly?
Thanks.
Joe
Re: Thinned BLO - how long to dry?
Rob Stokes in North Vancouver
>Ideally a week. But I'd probably cheat and lay on the poly after a day. Less if I was pushed for time and knew the piece was to be warm, dry and undisturbed for a week or so later on (to let the finish settle down).
Curious why you sanded the slurry. Did that not muddy the grain?
Rob
>Thanks Rob,
I sanded and created a slurry to try to fill the pores a bit. It was suggested here a while ago.
Thought I'd see how it looks.
Joe
>Even though the BLO adds absolutely nothing to enhance the finish, it's OK to apply an oil based poly as soon as the BLO is dry to the touch. The poly probably contains a drying oil, which will amalgomate with the BLO, and the whole mess will cure together. Next time, go with straight poly or alkyd varnish. It can be thinned and sanded in, wiped off, and repeated as many times as wanted to achieve the desired build. It's a technique that many custom stock makers employ.
Clint
Bill White
>Just finished a box project w/ BLO.
Once a day for a week. Sanded it in as you did last two days. Final finish w/ tung oil varnish (3 coats wiped on). SMOOTH AND PURDY!!
Bill
Re: There is a difference, you know
Glenn Madsen near San Francisco
>Drying and curing.
Drying is the mineral spirits evaporating.
Curing is the cross linking that makes the finish harder.
Which is why the fellow above indicated that 1) you don't need BLO if varnish is to follow, and 2) you don't need to wait, really, to lay down the oil poly.
Some old habits die hard. Want a gallon of BLO? ;-)
Yes. I know. Thank you.
HMMM????
roninkokomo
>PLO will serve to pop grain that otherwise might not look so spectacular
