Slots for knifes
BrianA
>I want to make a knife block out of a solid hunk of wood, but do not want to cut it into strips to cut out the notches where the knives slide in. Any ideas how I can cut the holes? Hope I am making my self clear.
Brian
Slots for knifes
BrianA
Brian
Re: Slots for knifes
Howard Norman
>No, will be interested to see if someone has an idea on this.
>Good luck! Standard practice for building them is to laminate the wooden block and "build" it around the slots. As most knife slots are thin and long, you couldn't use a standard mortise chisel bit. The thinnest mortise chisel bit that I've seen is 1/4". That is a bit fat for a knife slot.
BrianA
>That was my instinct. looks like I will have to cut up a perfectly good hunk of wood and then put it back together. Unless we find someone smarter than we are ;-)
Brian
I suppose in theory
Bill Houghton, California cold in Sebastopol, CA
>you could drill a bunch of holes in rows where you wanted the slots and then worry out the rest of the wood, but I imagine it'd take you about ten times as long as laminating, and it would be hard to make it look good.
Re: I suppose in theory
steve mackay
>That was MY first thought but gotta agree, it would probably drive one insane. Going on, "in theory" : drill the holes as far as one could then use an old knife, red hot, to burn through the length (could get messy). Going WAY out there : LASER ? Don't know if a readily available LASER would go that deep ? Always wondered how they made Japanese sword scabords untill I saw it on the Dummy Box. Kinda surprised me.
>Many years ago I made two. On one, I sliced one side off the block with a band saw. It did not fit back on perfectly, so I dressed both the block and the slice on the jointer. Cut the slots in the block with a table saw, making them slightly over sized. Glued the slice back on. Good grain match, but not perfect. One the other one, the block was too thin to start with, so I just cut eh slots in it and glued a separate piece on it. Works fine, but no grain match at all. Gave the gooder one away.
My Idea
>Good Afternoon Brian,
I'd try using a scroll saw because its blade is pretty thin to begin with. You'd have to be especially attentive to any natural drift/grain direction. Then I'd glue on some sandpaper to a thin steel putty knife blade and use that to widen and even out the kerf.
After loosing my patience eventually, I'd do it by lamination. :<)
Then I'd spend time removing the sandpaper/glue from my putty knife.
George
I did mine the same way
Bruce, a MN Galoot
>I've made 4-5 knife blocks, and most were done the same way, slicing off the outside layer and gluing it back on. Much easier this way.
Bruce
LOL !
steve mackay
Re: My Idea
Ken Oakley-Sunny St. Cloud, Fla.
>I read someplace the Chinese have trained dry wood termites to do that job. All the Chinese have to do is clean up up the termite poop when the job is done.
Slice it up
Chris Knob
>On a bandsaw...joint the edges...cut the slots and reglue. What are we talkin about here? In the absence of a plasma cutter or a phaser, this is impossible. A chisel...dear god!!!!
Re: My Idea.....Even better....
>Get and Ov Glove from that Idiot on TV. Better get two. Heat your knives to about 2000 Degrees. (Does not matter if it is Fahrenheit or Kelvin, just get them close to the temperature of the surface of the sun at high noon.) Holding them in tongs you are holding with the Ov Gloves, plunge them into the block. Have a lot of water or a fire extinguisher handy. Be sure to disconnect your smoke alarm and your security system and the Onstar in your car. After they cool off (a day or two if you got them hot enough), throw your knives away and buy a matching set. Voila!
Fred Davis
>We have a set of Chicago Cuterly knives which are in a laminated Oak block , they did not match any grain, side pieces may have been a continous strip cut to length, the middle piece is a markedly different grain and all stained same color.
So......... If I was to duplicate this block, since I have a moulder with chisel knives , that would be the machine I used, very much smoother cut , of course you can use a Dado set, or a router, just more difficult.
FredD
Cheat...
Ralph Turney
>If like you say, you already have a block that you want to use, cut it into the approximate size you need...maybe a little bit bigger. Next you cut about a half an inch of the top surface, the surface that the knives will go directly into. Then very carefully use the scroll saw to cut the slots into the top surface, transfer the slots onto the rest of the block and cut it apart, make the matching knife slots and laminate it back together again. Now, glue the two pieces back together lining them up with well placed biscuits (end grain to end grain). And finally, to hide that awful end grain joint, use thin veneer that you will make on the band saw using the same wood that you had left over and wrap the whole thing with it, round over the edges and you're done...
On second thought, just use the lamination method.
Dick Coers
>Would that be "frickin' sharks with frickin' laser beams attached to their frickin' heads," Doctor Evil?
Lilliputian Chain Saw
mdclor
Re: Cheat...
BrianA
>Thanks Guys,
Guess no one is any smarter than I am ;-)
I do like the heating the knives to the temperature of the sun, but my Weber will not do the trick.
Slicing it into 3- 2-3" thick blocks and using a scroll saw to cut the holes and gluing it back together does sound like an option.
Thanks
Brian
No, no, . . . Sea Bass !
steve mackay
Here's the Easy Way on the Tablesaw
Garrett in Victoria
>I've made several the same easy way.
This is a lot harder to describe than do.
Glue up a block over-sized to fit the knives, and about half again as long as your longest - probably the hone. Hardwood preferred. Joint and plane it and slab 1/4" off the sides that do not show glue lines and set them aside for later.
Now, decide what knives will go where. Assuming you will have two rows of knives:
1) on each of the sides showing the glue lines, physically line the knives up for spacing, and mark where the blade slots should be. Number the knives and the marks. (Make sure the two widest blades don't align directly one over the other.)
2) remove the knives, rotate the block 90 degrees, and mark the length of each on the one of the sides numbering each of these marks to its corresponding mate on the other side.
3) put a 1/8" wide blade on the saw, and set the height to the widest part of blade 1. Place the block beside the saw's fence and adjust the fence so that the blade 1's mark is centered on the blade. If you don't want to run the cuts all the way through, mark a stop point on the fence. Add an inch in case the curve of the knife and the blade mismatch. Cut the groove.
4) repeat for all knives on both sides.
5) skim the grooved sides over the jointer to clean them up, and glue the slabs to the grooved sides. Clean any excess glue out of the outer portions of the knife slots.
6) if you have a round hone, you'll need an extra long drill bit of the right size. Clamp securely, drill slowly, and clear often (IMPORTANT!!!).
7) trim the slabs, and lightly joint and plane the block.
8) Cut the angle you want for the bottom, and make and attach a support for the upper end.
Finish however you like. I've left some natural and stained others.
Cheers, Garrett
now that's a clever solution
Bill Tindall, E.TN
Re: Here's the Easy Way on the Tablesaw
BrianA
>Good idea, but my block is not a block but with curves etc. But good idea. Took me a minute to figure out where you were going till I looked at the photo while I read.
Thanks!
Brian
