OT- GPS again.........
Jesper, Denmark
Jesper, Denmark
>I am about to invest in a Pioneer AVIC-F900BT in-dash GPS with all the bells and whistles, like radio, DVD and bluetooth capability for the telephone.
There were some difficulties with these a year ago where the Traffic alarm system caused a processor lock-up. I wonder if anybody has any experience with this unit - good or bad? When I look at the way the menus etc. are set-up, I get the impression that they are actually using a Garmin engine for the GPS and Pioneer technology for the rest.
I am now using a Garmin N�vi, which I like, but it has very bad sound on the telephone and I have not found a neat way to mount it in the car. I hate those wires hanging around and also the suction cup hickies on the windshield. Since we will be driving a rather complex and long route from here to the south of Spain in late January, this would be an improvement.
I will still be using the Garmin for rentals, whch I use often.
Re: OT- GPS again.........
wilbur
>I installed the AVIC F700BT a couple of months ago n my Toyota Camry. It's pretty much the same unit as the AVIC F900BT, minus the DVD and MSN Live for traffic. I've found that the unit runs on Windows CE, that the GPS software is a version of IGo 8.0, and that the map data comes from Teleatlas.
I like my unit, with the exception of:
1. Boot up time could be faster. It goes from off to FM radio in about 5 seconds, but going from off to iPod is about 35 seconds, and the GPS also takes about 35 seconds to boot up. Connecting to the phone via Bluetooth is a little over a minute. Not a showstopper, and you do get used to it.
2. Transferring phone numbers from my phone (Motorola Z9) to the AVIC F700BT resulted in multiple phone entries without any indication of what the entries were. That is, I would get three entries for "John Smith", one for home, work, and mobile phones. But I couldn't tell which entry was which. There's a way to edit the phone number data base that involves hacking the unit to get to the Windows CE environment, copying the phone number database to an SD card, and editing that file on another computer, and copying it back. I do think that this depends on which phone you have. For example, the iPhone seems to have no problems.
On the plus side, iPod integration is very good, the GPS works very well, and the sound is fantastic. I also like the fact that this unit isn't covered in fluorescent lights.
Overall, I'm happy with this unit. The above issues with boot up and phone numbers are annoying, but not a deal killer, and I would get this unit again.
There's a forum for Pioneer AVIC units, with tips on hacking it. I've disabled the device that requires you to be stopped and have the parking brake set to change any of the GPS destinations.
http://www.avic411.com/forum/
The Garmin Toyota phenomonen *LINK*
>You seem to know a thing or two about these.
There seems to be some sort of problem with the Toyota Camry and the entry level Garmin Nuvi GPS units. Something to do with SiRF and evil gremlins that are in the newer model Toyotas. If I try to use my Garmin Nuvi 200W in my 2007 Toyota Camry, it can't receive a satellite signal. Doesn't matter if the car is driving or parked, running or not. It just doesn't work. Many say it's the windshield, but I can open my sunroof and hold the GPS up outside and it still doesn't work.
But take it out of the Camry about 25 feet and it works fine. Works just fine in my Honda Odyssey and other cars. Toyota denies any problem. Garmin denies any problem. But it's a problem proven and documented by many people including myself.
I've posted on a forum that discusses it.
Any thoughts on this?
Happy Woodworking!
http://www.gpsmagazine.com/comments/000434.php#com
Jesper, Denmark
Re: Ask a silly question.......
Jesper, Denmark
>....and on this forum you always get a complete answer.
Thanks Guys, and
HAPPY NEWYEAR
Re: The Garmin Toyota phenomonen
wilbur
>Hi Mark,
I don't think I'll be much help with this issue, although now I am now surprisingly happy that my Camry is 10 years old. :@)
What I can say is that when I was installing my unit, one of the things that people seemed to have issues with was the location of the GPS antenna. From reading other's experiences with installing this unit, it seemed that if there was any metal between the antenna and the sky, the GPS had a very hard time acquiring the satellite signal. It was possible to install the GPS antenna under the dash, IF there weren't any metal parts, such as structural frames, above where the antenna was mounted, and IF the GPS antenna was far enough forward so that an imaginary vertical line from the antenna location would go through the windshield and the top of the dashboard without the roof of the car being in the way. I wound up putting the antenna on my front dash, on the passenger side, down where the windshield met the dashboard.
If there was increased metal content in the glass in the windshield, I could see how this might interfere with acquisition of the GPS satellite signal, but this doesn't explain why you can't pick up the signal by holding the Garmin out through the sunroof.
Jesper, Denmark
Re: OT- GPS report of installation...
Jesper, Denmark
>I did select the AVIC-F900BT and had the dealer install it with matching trim to fit the car.
I am impressed with the map data although they are from 2007. The speed limits are accurate for the most part to within 20 feet and the detail is very good. The phone connection to a N�kia 3110 was trouble free and the sound on the phone is much better than anything else I have tried.
The Danish language is a joke. It sounds like an 85 year old grandmother with advanced senility. The language engine must be in another kanguage, as the syntax stinks. Fortunately English is OK for me and is a better language, although the TTS cannot figure out how to pronounce the Danish street names etc.
There are too many features to have found them all, but the basic operation is good and I will get weaned from the Garmin philisophy that I am used to in time.
It will be interesting to hear if the TTS will do better later this week in Germany, France and Spain.
The only really irritating part is not directly related to the unit itself. The installation makes the screen flush with the dash, and there are some disturbing reflection from the light from the right window.
Boot up time does not really seem to be a bother and the number of satellites it tracks is very impressive, even though the antenna is hidden under the dash.
The next move and following move large symbols in the left top of the screen are very helpful. It is less helpful that it will only display heading up in 3D mode. 2D mode makes it North up, which is illogical when driving, but there are more detail on the 2D display.
Speedtrap download was simple, but firmware upload was not successful and the support from Pioneer less than stellar.
later this week, it will be teated on a 2500 mile complex trip through Germany, France, Spain and Portugal. I may have the Garmin along as a back-up and maybe compare the two on some stretches.
The POI list is also very impressive with much more than the Garmin, daown to some shops etc. in this very small community.
brandon mclean
>Very nice model!!
