Can you make gap filling yellow glue?
DizD
>By adding wood flour like you do to thicken epoxy? Would this do any more than thicken the glue? Any downsides to putting cellulose filler in yellow glue?
DizD
Re: Can you make gap filling yellow glue?
Ronald from NW Ohio
>i just put a little saw dust in with the glue. It works okay with me but i am not hard to please either.
Tom Dunlap
>When I need a putty to fill holes I get out my sander and make some from cutoffs. Then I mix it with glue. I don't ever count on the putty to act as an edge adhesive, just to fill airspace. On most projects, knock on wood [my head :)] I've had good luck with the finish taking the same on the putty holes as the wood.
Chris Knob
>Can you make a mizture of wood and yellow glue that will fill gaps? Yes. It will have no structural strength, just fill in the voids.
Depends on the gap.
>No real structural strength. Not too much bridging. However - it doesn't stain well, so why bother?
Greg
>It does not make a good gap filler as it will sag as it dries. Adding fine sawdust to the glue will help stiffen it, but the color never matches exactly and stains accentuate the differences in color.
You might try cutting a small sliver of the same wood you are using and wedge it in the gap with a small amount of glue on it and then flush saw it off.
Greg
I agree with Greg
paul in AZ-
>Using a sawdust paste to fill gaps sounds like a fine idea but it has never been a successful solution for me. It always shows and can look worse than the original gap.
Slivers of the same wood glued and tapped into gaps or even inlaid into bigger voids gives a result that can be so hard to spot that the average looker won't notice the repair. I actually think it is kind of fun to conceal my errors. Maybe my joinery is worse than most but the challenge of fixing mistakes is part of the satisfaction.
Chuck in ND
>No, but you can make a gap useing Gorilla glue if you don't clamp the wood.
Chuck in ND
>This question reminds me of a home contractor that was fairly new to the trades. We had got the bid on painting the interior, staining and laquering the woodwork on one of his homes he built. One day he comes over to our boss and points to what looked to be about a 1/8" gap in one of the miters in the door trim and asks if the laquer would fill that gap.
I had the converse happen.
Jason Roehl in Lafayette, IN
>I was painting a new house where the carpenter had fancified the window trim a bit by bumping out the top horizontal casing where it would normally be mitered to the vertical pieces--faux columns, if you will. Anyway, the carpenter had glued and clamped all the small pieces together at the miters. The builder saw me skip caulking the inside miters and wanted me to do it--a lot of extra work, as it was a busy trim profile. I told him I wouldn't, as by the time I used a wet rag to wipe out all the excess caulk, it was no different than paint, and there was no gap to speak of anyway. This was a builder that would dump a contractor for another if the other guy was a nickel/sq.ft. cheaper. Plus, he didn't want us to spray anything, was (overly) picky (for the price), etc. His business didn't last long...
Jason
To sum up......
Howard Acheson
>... the only adhesive that can bridge gaps and still maintain full strength is slow set, two part epoxy. All other consumer adhesives require tight contact between the wood surfaces. The adhesive provides not real strength by itself.
Re: To sum up......
DizD
>Thanks all. Should have specified that I'm starting to assemble some joints w/ loose tenons. They're reasonably tight but there are always some small voids. Probably ought to do a few samples and cut them open to see what the joint looks like.
Re: To sum up......
Chuck in ND
>Try one with yellow glue, and try one with Gorilla glue, I'd be interested in the outcome. I'm thinking Gorilla glue will fill any of the voids nicely. It's what I use for joints with some voiding, like chair rungs, etc.
Re: To sum up......
>Small voids are ok. I have also used fiberglass screen material to fill in the voids for really loose tenons as well as drawknife shavings.
Re: To sum up......
DizD
>My understanding is Gorilla glue will expand, but the foam has no strength. I've about quit using it.
Re: To sum up......
Chuck in ND
>Oh I don't know about the foam not haveing any strength, the stuff seems pretty hard once dried on a squeeze out. I think someone just started a vicious rumour, I've never had a problem with it. I've used it on tablesaw cut box joints for coin banks and the joints have held up very well, infact two of the banks went to my young nephews, so I'd say they are tested kid tough.
