DELTA 36-865 Versa-Feeder & similar: anyone use? *LINK*
Dan Mitchell
>I see Rockler has the DELTA 36-865 Versa-Feeder, regularly $310, on sale for $100, which seems like a deal. Anyone have this model or a similar item? Opinions?
Dan
http://www.rockler.com/product.cfm?page=18235&filt
Re: DELTA 36-865 Versa-Feeder & similar: anyone use? *LINK*
Fred Davis
>I have a couple of Delta 36-850 stock feeders which at 1 HP is about right for a dedicated rip saw and one on the router table.
1/8th HP sounds to weak to me and I notice there is very little vertical adjustment with that model.
Hope this helps
FredD
Had it...sold it
Chris Knob
>Its the stock Taiwan baby feeder sold by about a 10 companies. If you really need a stock feeder, you need more than this. I found out in using it that I didn't need a feeder...not enough production runs of stock to make the time spent in setup worth it. Power feeders are for the very paranoid or the very busy.
This one's an amusing toy
Re: Had it...sold it
mike@American Sycamore
>Dear Dan:
I have three different Delta stock feeders here at the school. The small unit works great on the router table for making mouldings. If you buy it with light duty use in mind you will be happy. It is not a heavy duty unit nor is it sold that way. Too many people try to be cheap and buy the wrong tool for the job based on price. If you need a heavier unit BUY IT!
Not only is a stock feeder so much safer you get a constant better quality of cut. I have the Model 36-850 that is set up on a tablesaw used for ripping tongue & groove ceder strips for canoe building. I have the model 36-851 set up on my three horse power shaper for raised panel door making. I am not paranoid nor in a big hurry! I demand a quality cut and I want to be in a safe control. Buy the feeder that will fit your work habits and your tools and equipment.
Good luck,
Mike
Fred Davis
>Good answer Mike and right to the point.
It's the only way to fly for consistant , safe repeatiblity.
FredD
Chris Knob
>Didn't mean to slight proud owners of the "baby feeder" (the sellers words, not mine) but I did point out power feeders were a waste unless you have to produce lots of repeatedly consistant cuts. When I bought this one, I considered myself a pretty busy woodworker with a shaper to prove it! I drilled holes in my tablesaw and shaper tops to acommodate it and I looked forward to safer and reproduceable results. The feeder (I had the Grizzly version), even on its lowest speed setting, still fed stock too fast for my 2hp shaper and took an average of 20 minutes to set up properly through trial and error with waste stock before I would trust it in a run. For one or two cuts in the name of safety, it wasn't worth the time. For long runs, like the tongue and groove milling for our family room floor, the results were not of the "feed it and forget it" vartiety. IMHO, it doesn't have the stones or the XYZ quick adjustability to justify puttng one on your machine. Notice, I did not say it wasn't worth the price. It's a decent value of machine for the money...I just couldn't find a justifiable use for it and selling a piece of machinery, parting with one of my proud acqusitions, is truly saying something for this woodworker.
