How would you eliminate dowel-spacing error?
Nathan
>Hello to all, back in the shop (and on Woodcentral) after a rather long hiatus.
I'm joining two pine boards together at right angles using a butt joint reinforced with dowels.
The joint is over 6' long. I'm drilling the dowels 11" apart. I start on one end, drill a hole, move the board 11" by inserting a dowel in the hole and pushing the dowel up against a stop. Then I drill another hole, put a dowel in it, re-register, etc. etc. until the end of the board. I do that on both boards I'm joining. When I finish and go to dry fit the two boards together, the holes on the opposite end of the board are at least 1/4" off. I can deal with something like 1/16" but 1/4" is too much and I have to go back and redrill several holes.
What is happening is this: as I re-register and re-drill, the registering error adds up. I'd like to figure out how to eliminate the registering error. I think it's caused by two things: (1) the dowels are not perfectly dimensioned - some are a little thicker, some a little thinner. (2) The dowel could be tilting a little in the hole.
I have two ideas. First, I could start drilling in the middle of the boards instead of at the ends - that might solve the problem, except the way I have my machine set up, I can only set the stop on one side of the bit. So, I'd rather just eliminate the registering error. Perhaps I could get a steel dowel made to exactly the same dimension as my drill bit and use that instead of the wooden dowel to register?
Any other ideas?
P.S. I know I could use a biscuit joiner or a spline instead of dowels, but right now dowels are what I'm set up to do and I'd like to get to the bottom of this.
