Small tool dust collection
Larry_Wyatt(Cole's Dad)
>I want to fashion an appliance(hose boom, if you will) for the shop to aid with small power tool dust collection. Festool has a system(see below), but I'm not going to invest that kind of money when I think I can McGyver something myself. What I want is for the hose to be held in an overhead position. This would work beautifully with my Dewalt plunge router and other small power tools.
The question.....have any of you fashioned anything like this? I've got some ideas, but don't want to reinvent the wheel. I've Googled, but can't find anything.
Any help would be appreciated.
Thanks a bunch!
Larry
Re: Small tool dust collection
Bob Entwisle in NJ
>I have a few strategically placed hooks on the ceiling, mostly over my bench, that I hang power cords from when sanding or routing etc. I would think that with larger hooks, the same arrangement would work for suspending the vacuum hose above the work.
Not Festool, but would do the job
Of course I have an eight foot ceiling. A higher ceiling might be more of a challenge.
>A while back I bought a floor stand suction head. It works great with a dust collector. I use it mostly for my lathe, but I have used it to "sweep" air across the top of my bench.
Ed Mulligan, Cape Cod
>My rig is in the photo. The T supports channel dust escaping from under the work to the main dust collector duct. The green hose goes to the shop vac. A four foot plank is clamped in the bench vise, vertically. You can see part of the plank to the left of the router in the photo. The green hose for the shop vac runs to the top of the plank where a notch and a couple of spring clamps hold it in place.
Chuck in ND
>Bob, you mean like maybe those rubber coated large hooks to hang bicycles ?
Alan in Little Washington (NC)
>This is what I do for small tools like my ROS, biscuit joiner, router, etc. I have a standard Shopvac in a cabinet (for noise abatement) connected via a mini-cyclone to 2" PVC electrical conduit (has longer radius bends than regular PVC.) The conduit runs above the cabinets to my benchtop mortiser and miter saw. A branch line runs along the ceiling to overhead my assembly table where it is connected to a hose drop.
>Thanks for the great ideas, everyone! The hook from the ceiling gives me an idea. I have a 10 foot ceiling, so I could install a hook and then hang a bungee cord from it, attach the bungee to the hose and voila'! Perhpas that might work?
I wonder if anyone has made anything out of PVC pipe?
Thanks!
Larry
Bob Entwisle in NJ
>Chuck,
Yes those hooks would be perfect.
Check out THIS idea!!
>Check out this idea. This would accomplish what I wanted...to get the hose high above the tool, but I suspect there's a better way.
GalenV
>Alan
That has to be the worlds stongest shop vac to keep your shop looking that clean!!!
My shop vac is a cheap Sears and you just about need to drop the chips in the can by hand.
I just wish I had that kind of shop.
Galen
Inner tubes...
Ralph Turney
>I used to have used bicycle inner tubes just screwed into my ceiling that hung down in strategic places around the shop. They can be easily tied up out of the way and it's very easy to wrap them around a hose (no knots needed, just do it like when you give blood) and make them just the right height for the job at hand. Granted, it's not the most elegant way to tie up your hoses, but it's very effective, fast and cheap (I always have old tubes from my road bike lying around). And with your 10' ceilings, you don't have to get up on a ladder just to wrap your hose around a hook. You just keep the tubes tied up above your head so that you can reach with your hands.
>The Shopvac only picks up from a few locations. I have a big DC for everything else. I cleaned up to take pics for the Top Shop Contest.
