Refinish Wood Handled Kitchen Knives
Steve in Phoenix
>We have a nice set of Chicago Cutlery and I would like to refinish the wood. They need a good sanding, and in the past I had used mineral oil annually. However, I would like a more permanent and durable finish. Any suggestions?
Thanks!
Steve
Re: Refinish Wood Handled Kitchen Knives
Pete LaBelle
>Oil finishes on the cutlery handles are more durable over the long run. Sealed finishes will scratch and don't do well in the dishwasher. Besides, it leaves the handle more "grippy" and not as apt to slip in your hand.
Refinishing knife handles? Sounds like you are bored and looking for something to do ?
Brian Hahn in SW Wisconsin
>I treat all my bare wood knife handles with linseed oil. I heat a small container of oil (double boiler) and put the handle in the hot oil. Leave the handle in until the oil has cooled to room temperature. This will draw the oil into the wood. Let the handle dry for a day or two and repeat twice. The handles I've done this way have survived many trips through the dish washer.
Dale Lenz
Dale Lenz
>Back in the early 80's I replaced a few of my mothers Sear's knife handles with pecan, the species that they were made of. Finished with spar varnish. Worked fine, dishwasher and all.
Howard Norman
>I have just used mineral oil myself. I like the idea of soaking them in hot linseed oil but have never tried it myself. I am of the belief that any good knife should not go in the dishwasher independent of the handle material.
Thanks for the responses...
Steve in Phoenix
>Lee Valley has a varnish oil that is a combination of spar varnish and lindseed oil. Perhaps the best of both worlds?
After reading your responses, I was considering treatment with mineral oil first, letting it dry for a few days, wiping with denatured alcohol to clean up the wood surface, then applying the varnish.
What do you think of multiple coats of wipe-on polyurethane as opposed to lindseed oil or spar varnish?
I put a cyanoacrylate finish on mine.
Michael Dresdner
Doug Ridley
>I hope nobody puts one of my kitchen knives in the dishwasher 'cause I bleed!
Bill White
>Oil w/ BLO and NEVER put 'em in the dishwasher.
Bill
