Re: Barbed hinges
Dick Coers
>I love those things. I use my shaper with a router bit collet so I can run the blade at a resonable speed. A router just seems too fast for a saw blade. I put two stops on the fence, equal distance from the center of the saw blade. I put the lid or the box against one of the stops, then rotate the part into the saw blade. Do that twice for the lid and twice for the box.
I don't remember what the distance from the outside edge I use, but too close and you will buldge the wood. I chamfer the lid and the box on the back so the lid will open just over 90 degrees. I also don't like the distance that the lid stays off the box because of the knuckle of the hinge. I use an X-Acto knife and basically mortise in the knuckle into the box.
Man, that sounds confusing. Sure wish I had a box around to take a picture. If this is too bad, send me an email and I will make a sketch.
