Router speed
Router speed
John Pierce
Router speed
john pierce
>I just fired up my PC 8529 router after a long absence of any work. I discovered that it spun up to speed and then promptly began to shut down, finally arriving at a very low, un-useable, speed where it continued to turn until I turned the power switch off.
Does anyone have an idea what may be behind this strange behavior?
John
Re: Router speed
Re: Router speed
Bob Entwisle in NJ
>First off, I'm not familiar with this router.
That said, barring a mechanical issue, such as seized bearings etc, which should be apparent from (unplugged) manually turning the shaft etc. I would take a look at the variable speed controls, specifically the speed adjustment control, it sounds like you are in permanent low speed mode, could be dirt or dust obstructing a contact in the variable speed adjustment control.
Re: Router speed
John Pierce
Re: Router speed
john pierce
>Well, I found the problem. It was the speed control which apparently was at a dead spot. After I moved the speed control the Router worked fine.
John
Re: Router speed
Dust in the reostat
Phil Joines in Krum, Tx
>There's probable some dust in the pot. Sounds like a gentle blow with compressed air is in order.
