Delta 14" Bandsaw
Delta 14" Bandsaw
Delta 14" Bandsaw
Ken Oakley-Sunny St. Cloud, Fla.
>When I bought my bandsaw 10+ years ago I also purchased the riser block, which I installed as I assembled the bandsaw. I also purchased a set of Carter blade guides which I never got around to installing. Last week the lower thrust bearing on the Delta guides froze, so yesterday I installed the Carter system. Just have to modify the blade guard a bit to fit the new setup. Being in a tuneup mode I am thinking of replacing the tires on the upper and lower wheels. The original ones are still on the machine. Need suggestions as to which ones to buy. Carter has Blue ones, neoprene ones and hard ones. I have never changed tires so I am a Newbie to it. I need all the help I can get.
Re: Delta 14" Bandsaw
Chris Knob
>No experience with the aftermarket Carters but I will advise you to remove the wheels before you attempt to replace the rubber. If the original Deltas lasted 10 years, it sounds like they are more than adequete.
Call Iturra
Rod Peterson -- Ormond Beach
>Before you go too far fooling around with upgrading, give Iturra a call at (904) 642-2802 and request their catalog. They're in Jacksonville, but unfortunately, they don't have a web presence. However, the catalog is practically a bible for Delta band saws, and in addition to good ideas on tire replacements and possibly information on the guides, you will likely be interested in a replacement tension spring, particularly with the riser block mod.
Their catalog is to Delta (and other) bandsaws as the Mr. Sawdust (Wallace Kunkel) book is to radial arm saws.
Rod
>Ken,
I bought two sets of tires from Iturra, one for my 14" Delta and one for a friend. They seem to be very good tires.
The things I did to and for my Delta:
- high tension spring (Iturra)
- quality sealed thrust bearings (Iturra)
- wheel shims (Iturra) - for aligning wheels
- tracking arm (Iturra) - original was bent
- Carter quick release (Woodcraft)
- Cool Blocks
- tire brushes (homemade and Iturra)
- Starrett tension gauge (Iturra)
BTW, I tried Carter guides and didn't like them.
Note that the lower thrust bearing almost always goes first, since it collects more junk and is out of sight and out of mind. We tend not to keep it properly cleaned. I bought a few extra bearings to have on hand.
tek,brunswick
>which modifications seemed to be the most beneficial? Were there some you didn't think were worth the time ,effort and money?
Thanks
>-which modifications seemed to be the most beneficial?
In approximate order with the most useful first:
- The high tension spring, tracking arm, and tension gauge allowed me to tension properly to resaw and process thick turning blanks.
- The quick release saved me the most time (would not apply to those who never detension when not in use).
- The shims allowed wheel alignment to improve the cut.
- The cool blocks prevent destroying the blade if the guides are accidentally set improperly.
- Tire brushes help keep the wheels clean to prevent buildup on the blade from cutting green wood.
- Sealed bearings increase the time between failures.
The only thing not worth the time was my first tire brush which I made from a small scrub brush and had to devise a way to mount it. I bought the second one from Iturra and it was far quicker to install and didn't cost much.
